Driveshaft Jd314 Hydro
5 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted November 25, 2012 - 06:00 PM
I have a 1980 jd 314 that I need to know how to remove the driveshaft so I can remove the yoke on the hydro. I believe the pin came out of the yoke and it looks like the hole is quite wallowed out. Any help would be appreciated.
Thanks larryd
#2 olcowhand ONLINE
  • 41,055 Thanks
  • 31,392 posts
Posted November 25, 2012 - 06:05 PM
I'm not familiar with the 314, so I'm of no help, but there are plenty of JD guys that will be along soon to advise.
#3 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted November 25, 2012 - 06:24 PM
larryd... :welcometogttalk:
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted November 25, 2012 - 08:14 PM
Larry, that's a common problem on 314's. You will likely have to remove the engine to get the shaft out. The couplers were still available from JD the last time I checked. I replaced the engine side coupler on my 314 last year. The thing to look for is wear on the input shaft of the hydro. That can be so bad that the shaft or the entire hydro needs to be replaced. Check your motor mounts as well. If they are bad then it causes extra wear on the shaft couplers due to increased engine movement.
#5 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted November 27, 2012 - 09:03 AM
Hello gentlemen. I found out on my 314 that you remove bolts from drive shaft and remove the seat pan the shaft can be moved out of the wat and the coupler can be easily removed .
So I am know trying to find a coupler from a John Deere dealer.
Thanks for your input.
larryd
#6 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted November 27, 2012 - 09:09 PM
I'm in the same situation w/ my 314. I found driveshaft components on vernondelltractor.com. The front and rear hubs are $24 & $28 each. The shaft is $56. I checked w/ my local machine shop and he will make me a new shaft w/ keyway and pin hole for $35. I'm going to order the new hubs soon. Bought a used hydro from Joe's outdoor power and it should be on the way.
Mike
