46" Blade And Nothing To Do With It!
13 replies to this topic
#1 dropped82 ONLINE
dropped82
    Nut Case
  • 2,633 Thanks
  • 1,869 posts
Posted November 24, 2012 - 01:19 PM
I have the 46" JD blade with no tractor for it. I had it when I used my long gone LT to push snow. So my question is, what should I do with it? Its in great shape. I thought about building something else with it. I'm looking for ideas and opinions from everyone. Thanks.
Eric
Sent from my SPH-D700 using Tapatalk 2
#2 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted November 24, 2012 - 01:34 PM
Give it to another GTT member! HINT: me me me!!!!
LOL
Geno
  • dropped82 said thank you
#3 Ryan313 OFFLINE
  • 3,403 Thanks
  • 5,240 posts
Posted November 24, 2012 - 02:51 PM
Have a tractor with a 3 point? Make it into a back blade! I have been looking for a 5 footer that I could make into a back blade.
#4 shorty ONLINE
shorty
  • 5,773 Thanks
  • 5,390 posts
Posted November 24, 2012 - 02:52 PM
Trade for a different attachment. Or if you like to do any fabricating you could fit it to another.
#5 MH81 OFFLINE
Posted November 24, 2012 - 02:57 PM
I hear the makings of a build thread...
#6 KC9KAS ONLINE
KC9KAS
  • 5,443 Thanks
  • 4,710 posts
Posted November 24, 2012 - 05:01 PM
:iagree: Trade for something you need, or build something different with it.
#7 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted November 24, 2012 - 06:22 PM
buy a gt that would fit it
#8 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,643 Thanks
  • 1,318 posts
Posted November 24, 2012 - 06:39 PM
i have my eye on a 5ft 3pt cat.0 grader blade not far from me.i used to have one like it and i loved it.its only the second one i have seen.
Edited by rustyoldjunk, November 24, 2012 - 06:41 PM.
#9 dropped82 ONLINE
dropped82
    Nut Case
  • 2,633 Thanks
  • 1,869 posts
Posted November 24, 2012 - 07:09 PM
I don't have a 3 pt. I have a sleeve hitch. I thought about a back blade or even making a grader box but can't really think when I will ever use it. If someone wants to swap me for a JD 43 blade, I would good with that. The one I have is for a JD LT. The 100/L100, so on series mowers. It has the complete mount and handle for lift and pivot. I was thinking of making a front trip shovel from a 43 blade for my 112. Any takers?
Edited by dropped82, November 24, 2012 - 07:10 PM.
#10 dropped82 ONLINE
dropped82
    Nut Case
  • 2,633 Thanks
  • 1,869 posts
Posted November 25, 2012 - 04:46 PM
I guess no one is interested. Hmmm, I want to make it into something. I guess a back blade may get more use than a grader box. I don't know yet though.
#11 KennyP ONLINE
  • 40,102 Thanks
  • 46,756 posts
Posted November 26, 2012 - 07:48 AM
If you were closer, I'd look into it. Maybe you could build a different mounting for it so it would fit what you have? Got a pic of it?
#12 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 26, 2012 - 04:48 PM
There is a nearly new one sitting in the garage, I intended to make a rear blade for the 318. Now that I have a 6 ft rear blade for the Ford I'm not sure what I'll do with this one either, but it's sittng in the corner when I get a flash of brilliance(Hmm Those don't come as often as I get older?).
#13 glgrumpy OFFLINE
  • 8,720 Thanks
  • 7,973 posts
Posted November 26, 2012 - 08:20 PM
Is this one of those ones for the L130 or similar light tractors? Has the mount for on front that will quick-attach if left on and has that real ong handle with the turn release lever? Takes two foot longer arms to operate and flexes to the next state when using it? I've had that one on my JD for 5 years and it has never broken really, but sure isn't much of a blade. The blade itself is OK, make a rear blade with it, or the grader box, which works better on gravel drives. The mounts and controls don't get MY vote at all.
#14 dropped82 ONLINE
dropped82
    Nut Case
  • 2,633 Thanks
  • 1,869 posts
Posted November 28, 2012 - 09:35 PM
Grumpy, you hit it right on the money. The mount and controls are not much to speak of. I used it quite a bit when I had my 115 auto. The blade is good and I think would make a great candidate for a rear blade. The mount and controls are on the other hand are good for scrap. I could easily make a rear blade just not real sure when I will use it. I also thought about trying to massage the mount a bit to fit on my RF 112 using the factory lift. I don't know yet. I have a 265 freebie I'm wrenching on right now till something lights up in my head.
