Vickers T66 - Seal Kit Needed
12 replies to this topic
  • 2,348 Thanks
  • 1,502 posts
Posted November 23, 2012 - 07:42 PM
My A/C HB112 hydro transmission has begun to weep. It has a Vickers T66 in it. The same hydro was used by Simplicity in their 310, 312, 314, and 416 series tractors. I suspect others used the T66 as well.
The seal kit part number is, or was, 2066516. All of the websites I've googled seem to list is as NLA.
Does anyone know of a working part number &/or a source?
Edited by New.Canadian.DB.Owner, November 26, 2012 - 09:05 PM.
#2 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted November 26, 2012 - 07:08 PM
Nobody? It was also sold under part number 103248. Here are the parts diagram & list.
Edited by New.Canadian.DB.Owner, November 26, 2012 - 07:08 PM.
#3 olcowhand ONLINE
  • 42,896 Thanks
  • 31,938 posts
Posted November 26, 2012 - 07:39 PM
I can't find anything. The part number is likely not the seal number as on the seal. If you had the actual seal number, it's likely readily available.
#4 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted November 26, 2012 - 08:49 PM
The seal kit contains all of the items with a "4" in the fourth column. At a minimum, I need items items 10, 51, 53, 54 and 65.
Item Part # Description
10 1650071 Shaft Seal
51 1650100 Plug
53 1650102 O Ring (x2)
54 1650071 Shaft Seal
65 1650112 Gasket
A "lottery win" would include items 52 (1650101 Pintle x 2) and 61 (1650109 Pump Housing).
#5 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,138 posts
Posted November 26, 2012 - 08:53 PM
Is a T66 the same as a T66X?
#6 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted November 26, 2012 - 09:00 PM
Yes, it is. The X indicates the assembly configuration of "Pump over motor with both shafts extending in same direction".
#7 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,138 posts
Posted November 26, 2012 - 09:04 PM
In that case: http://www.proactive...ansmissions.htm
There is a three year old thread on the web saying parts were available there, I have not verified that.
Edited by Cat385B, November 26, 2012 - 09:06 PM.
#8 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted November 26, 2012 - 09:15 PM
... If you had the actual seal number, it's likely readily available.
Don't I feel dumb. :wallbanging: Had I only looked at the items I actually needed, instead of the one I wanted, I would have seen that most of them are available on some of the very sites I had already trolled. Lesson learned.
#9 olcowhand ONLINE
  • 42,896 Thanks
  • 31,938 posts
Looks like Jack's Small Engines has that seal:
http://www.jackssmal...0071/2254862/PL
Simplicity USE 1650071SM
Part#: 1650071 Supercedes to 1650071SM
$14.85
Qty:
#10 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted November 29, 2012 - 01:01 PM
I found a seal kit! PRO-ACTIVE Fluid Power sells the kit under part number 923428_. It is their replacement for the OEM #103248 kit.
The kit & shipping to Canada was under $100, but that may have been a sale price. I'll post an update once the kit arrives & again once I get time to install it.
PRO-ACTIVE Fluid Power, Inc.
44383 Reynolds Drive Clinton Township, MI 48036 USA
Call: (586) 465-6708 press option # 4
Toll Free: 800-398-5733
Fax: (586) 465-6709
email: insidesales@proactivefluidpower.com
www.proactivefluidpower.com
#11 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted December 18, 2012 - 10:56 PM
I received the seal kit yesterday & I found time today to photograph it. I also found time to replace the seals, but that's another thread.
Here is what you get:
seal kit 1.jpg seal kit 2.jpg Attached File  Gaskets.pdf   132.99KB   107 downloads
The kit had more than I needed, but everything was topnotch.
  • Cat385B said thank you
#12 the_nite_owl OFFLINE
the_nite_owl
  • 6 Thanks
  • 9 posts
Posted July 16, 2015 - 11:41 AM
I know this is an old thread but it has a lot of useful information and I am hoping to expand on it.
Many of the bearings and seals used are now listed NA with no details about their specifications so if anyone can fill in some blanks on these we can begin sourcing parts elsewhere.
If you can fill in the sizes on any of these critical parts it would be enormously helpful during these rebuilds.
Part#                Description          Size
1650065          O-RING
1650066          O-RING
1650089          O-RING
2821349SM    O-RING                0.644 ID .087
2824003SM    O-RING                0.551 ID .070
1650068          Bearing
1650096          Bearing
1650106          Bearing
1650142          Bearing
Edited by the_nite_owl, July 16, 2015 - 11:44 AM.
  • olcowhand and New.Canadian.DB.Owner have said thanks
#13 TUDOR OFFLINE
TUDOR
  • 565 Thanks
  • 507 posts
Posted July 21, 2015 - 12:53 AM
Most o-rings and bearings are stock items if you have access to an industrial supply house.
If you can, take the old ones in and they can be sized at the counter.
