B112 Ignition Woes
6 replies to this topic
#1 salty OFFLINE
salty
  • 39 Thanks
  • 35 posts
Posted November 20, 2012 - 06:46 PM
I've been loaned a dead B112 to get some tilling done assuming I can get the tractor running. I've got strong consistent spark at the points when the engine is turning over and the "ignition" button is depressed. No spark at the points when the "ignition" button is not depressed. No spark at the plug. The wires disappearing through the shroud are prime suspects but it looks like I'll have to pull the motor to get the shroud off. Any suggestions on what I might test before going to all that trouble?
Thanks,
#2 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted November 20, 2012 - 09:13 PM
has this been rewired? The ignition button sounds like a kill switch but wired backwards. The wires going into the shroud should go to the mag. Pushing the kill switch will ground out the mag, causing no spark at the points. With no spark at the plug, my guess be open or shorted secondary on the mag if the plug wire looks good. The clip end will sometimes get rusty and cause problems.
#3 boyscout862 OFFLINE
  • 12,867 Thanks
  • 9,179 posts
Posted November 20, 2012 - 09:42 PM
Doesn't it have a key switch for on and off and a push button for the starter?
#4 salty OFFLINE
salty
  • 39 Thanks
  • 35 posts
Posted November 20, 2012 - 10:11 PM
I'd wondered about that button myself but figured it was a way to get extra voltage across the points for starting. It's awkward to push two buttons though so a kill switch makes sense. There's no keyed ignition switch either which seems unusual.
In the picture of the dash the start button below the steering column engages the starter. The "kill" switch, if that's what it's meant to be, is below the ammeter.
Thanks, Greg
#5 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted November 21, 2012 - 05:01 AM
sounds to me just as rat88 said, I've wired switches like that because I've had to not necessarily for fun. Wether it was intentional or not, it's killin your spark bud. I would just pull those wires and look for breaks in the wire or rust (again like rat88 said), because rust on that magnetto or any of its connecting points willl wreck havic on your day........
#6 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted November 21, 2012 - 06:49 AM
I believe someone has replaced the original off-on key switch with a normally closed, momentary push button switch instead of a normally open switch which should have been used as a kill switch.
If you want to go back with a key switch, you could use the Briggs & Stratton (part #392833) replacement for the original. Here's a couple of links that I found for that switch:
http://www.ebay.com/...9-/221124536912
http://www.jackssmal...92833/308717/pd
Edited by achomesteader, November 21, 2012 - 06:50 AM.
#7 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted December 07, 2012 - 07:15 PM
sounds like you got a double ground somewhere i have a toggle on and off but i start it with the orignal push button can you check the contnuity ?
whatever these guys will help you . in Christ Bobby
