Ignition Coil For Jd140
ignition coil jd140
9 replies to this topic
#1 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted November 20, 2012 - 03:27 PM
Hi guys,
a fellow here in germany has problems with a damaged ignition coil for a JD 140, serialnumber lower 22,400 - as seen in the pics here
These coils are no longer in stock. Does anyone know an alternative coil for use in a JD140? Does anyone can tell me the technical data of this coil, so maybe I can find an alternative here in Germany or Europe.
Thanks for your efforts :thumbs: :smiley-flag008:
Need to edit, because I forgot the pics :hitting_self_roller:
Edited by jd.rasentrac, November 20, 2012 - 03:36 PM.
#2 boyscout862 ONLINE
  • 12,834 Thanks
  • 9,160 posts
Posted November 20, 2012 - 04:00 PM
More information would help. What engine and what year. If its a kohler, theres abunch on ebay. Some auto parts stores may be able to get it for you. Good Luck
  • jd.rasentrac said thank you
#3 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted November 20, 2012 - 06:02 PM
I was gonna mention ebay myself....tons and tons of parts on there especially for JD's.....people are pretty fair in price if you search.
#4 hdg4400 OFFLINE
hdg4400
  • 284 Thanks
  • 348 posts
Posted November 20, 2012 - 06:26 PM
I agree, the internet is where to look. I've had really good luck searching on Part number in Google.
Harlan
#5 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted November 21, 2012 - 01:11 AM
Thank you guys for fast reply :thank_you:
Engine must be Kohler 301 - but I don't know exactly, the owner is living 300 miles away from me - because of the sn 015816. But the coil I can get in internet is this one kohler ign-coil.jpg which doesn't look like the original Foto0223.jpg as you can see. That the one you'll find in JDPC for the 140 from sn 10001 up to 22400 JD140+sn+10001-22400-1.png
And so I can't believe, that this kohler ign-coil.jpg fits this Foto0223.jpg (electrical coil, former part# AM32075 - which isn't in JD stock any longer...)
Edited by jd.rasentrac, November 21, 2012 - 11:52 AM.
#6 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted November 21, 2012 - 06:50 AM
Glad to hear you got the coil you need even if it doesn't look the same , maybe your friend will find one someday if he's looking for the " factory " look , Al
#7 boyscout862 ONLINE
  • 12,834 Thanks
  • 9,160 posts
Posted November 21, 2012 - 07:15 AM
They are two different types of ignition. The first is a magneto. It produces its own spark. The second is a coil. It needs electricity put to it to create a spark. Does the engine have points? if it does, there is a way to use the coil with the points. We need ACHomesteader
to explain how.
#8 Guest_gravely-power_*
  • Guests
Posted November 21, 2012 - 07:22 AM
The coil you have is for an electronic ignition. The one you show that you found will not work. This link should help you.
http://gardentractor...om/ignition.htm
#9 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted November 21, 2012 - 11:51 AM
Thanx for the link - i'll try to do my best to translate and inform the guy, btw, he's called Michael..
When I saw the photo of the coil I knew, that is was for electronic ignition. And as written in # here, JD hasn't it any longer in stock.
Normally you'll find technical informations printed on the coil - white on black. Michael said, that he doesn't find such infos on his part. And I couldn't find any further information in the Deere online service gates. So if there are technical infos on the wrap of such a coil for the JD140 then it would be nice to upload a photo here.
Maybe we will find an alternative coil, from BOSCH or HELLA or any other brand, or the whole ignition must be altered - or Michael needs an other engine.
#10 olcowhand OFFLINE
  • 41,076 Thanks
  • 31,393 posts
Posted November 21, 2012 - 12:15 PM
Yes, that is a solid state ignition on that 140. There are no points, and not even drilled/tapped for points most likely, so no converting it if it isn't. I had a Wheel Horse GT14 with solid state ignition many years back.
Also tagged with one or more of these keywords: ignition coil, jd140
