Blade Help Please
utility blade
23 replies to this topic
#1 jadefox OFFLINE
jadefox
  • 15 Thanks
  • 49 posts
Posted November 20, 2012 - 01:32 PM
So clearly I do not have the utility blade for my 448 that is consistent with the operator's manual in my file. I believe this is a blade that, unlike the J-Blades, does not use an adapter for the lift arm, but instead goes over the front axle. I've searched for an appropriate manual to no avail. Does somebody have one they can send me electronically, or might somebody give me some pointers on properly mounting this blade. Cheers in advance!
#2 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,088 Thanks
  • 1,284 posts
Posted November 20, 2012 - 01:54 PM
Hey, Any chance you could snap and post a few pics. It might help with the identification but also we all just love looking at pics.
#3 jadefox OFFLINE
jadefox
  • 15 Thanks
  • 49 posts
Posted November 20, 2012 - 01:57 PM
Hmmm....I thought I had attached a picture...lol. Let me try again.
#4 jadefox OFFLINE
jadefox
  • 15 Thanks
  • 49 posts
Posted November 20, 2012 - 01:59 PM
Here's a picture...
#5 jadefox OFFLINE
jadefox
  • 15 Thanks
  • 49 posts
Posted November 20, 2012 - 02:00 PM
Also on the list of fun things to address, the angle locking pin was last removed prior to the Civil War.
#6 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted November 20, 2012 - 05:57 PM
That looks like a heck of a blade...pretty strong....sure it can be put to use on somethin....somewhere....
#7 jadefox OFFLINE
jadefox
  • 15 Thanks
  • 49 posts
Posted November 20, 2012 - 08:38 PM
Agreed, but the task at hand is getting it on our 448 :-).
#8 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted November 20, 2012 - 10:54 PM
Got a 4 lbd sledge? That seems to be the answer to lots of questions on this site? Oh, that and PB blaster.
  • jadefox said thank you
#9 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted November 20, 2012 - 11:24 PM
That looks like some sort of re- worked hand lift mis- mash, not a "snap fast " mount that should be there to mount onto your 448....
On the maual lift, the lift arm should point towards the ground, and yours is at 2 O'clock.... And that sub- frame is not exacly right. SO, does two wrongs make a right? LOL
Has the tractor frame been modded to accept this blade and mount somehow?
Edited by marlboro180, November 20, 2012 - 11:25 PM.
#10 jadefox OFFLINE
jadefox
  • 15 Thanks
  • 49 posts
Posted November 21, 2012 - 10:20 AM
The frame does not appear to be modded, but this is my first CASE, so what do I know. ;-) I'll take some pics. I can mount mount securely to the frame using the snapfast pins and the mounting pins, but, as you said the lift arm is in the wrong position.
  • marlboro180 said thank you
#11 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted November 21, 2012 - 05:28 PM
Here's a pick and description of a blade that looks kinda like yours.
Date Listed 29-May-11
Price $250.00
Address Wilton, ON K0H, Canada
the blade works great i used it all winter to plow snow
wheel weights are case plasic weights and 1 needs to be filled
also comes with tire chains
came off a 72 446
will fit all 400 case garden tractors 442,444,446,448
250.00
613 386 1317
Maynard
Call
Send SMS
Add to Skype
You'll need Skype CreditFree via Skype
#12 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted November 21, 2012 - 05:32 PM
Here's another blade that looks similar to yours.
http://www.tractorfo...42-blade-18006/
#13 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted November 21, 2012 - 05:42 PM
.....and another link for you to look at. Go to page #4. BTW, it looks like this started as a 448 but somehow finished as a 449. Not sure what that's about.
http://data-cut.com/case448.htm
#14 heatseaker1 OFFLINE
heatseaker1
  • 27 Thanks
  • 36 posts
Posted November 21, 2012 - 07:46 PM
I've seen that page before. I think the guy goes by the username grummy on a couple other forums. Pretty neat modifications and fab work to get stuff to fit his needs.
#15 heatseaker1 OFFLINE
heatseaker1
  • 27 Thanks
  • 36 posts
Posted November 21, 2012 - 07:49 PM
I think it is in the right position and does in fact go over the axle. if you google eastman ingersoll, you will find the company that currently has the rights to the case garden tractor line and produces the ingersoll tractors. They have manuals for most of the older tractors and impliments on the site. Another good forum is GTtalk has an absolutely Terrific Case Forum, that is why I am a member here..com.
