Coil Pack Replacement On Briggs W/points?
10 replies to this topic
#1 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted November 19, 2012 - 09:19 AM
Is it as simple as upgrading to a new magneto style coil pack and snipping the wire to the condenser behind the flywheel? Or am I stuck getting an original style unit and pulling the flywheel to get to the condenser?
#2 undertaker OFFLINE
undertaker
  • 67 Thanks
  • 107 posts
Posted November 19, 2012 - 09:54 AM
thats the way I understand it as long as the magnetron is available for your model. I have asked the same question of a couple local techs in my area.
#3 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted November 19, 2012 - 10:00 AM
One would imagine it would work. Just wasn't sure if the magnets in the flywheel were different strength.
Posted from my Samsung Galaxy S III 32gb via tapatalk 2.
#4 DougT OFFLINE
DougT
    Dog Approved
  • 7,137 Thanks
  • 5,092 posts
Posted November 19, 2012 - 10:28 AM
The way I understand it, if its a single magnet flywheel there isn't a problem. If it is a 2 magnet flywheel the polarity of the magnetism needs to be reversed. At one tme, briggs woould do this in house for the cost of shipping. Not sure if it stil applies or not. What model engine are yu working on?
#5 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted November 19, 2012 - 11:22 AM
Not exactly sure the model. Where can I find this? I believe it's between a 5-7hp 70's vintage biggs horizontal shaft.
#6 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 245 posts
Posted November 19, 2012 - 01:50 PM
Check the top of the sheet metal pull start cover. check the picture below
I put a red arrow pointing to where the numbers should be.
Thats where mine is. I was able to shine a flash light in from the side by
air cleaner while looking down through the small gap between the
hood and steering wheel mount.
Edited by fxrs55, November 19, 2012 - 10:39 PM.
#7 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted November 19, 2012 - 10:33 PM
Looks like I have the original 5-3/4hp.
#8 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 245 posts
Posted November 19, 2012 - 10:44 PM
Cool, what is the model number? I'm just curious.
#9 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted November 20, 2012 - 07:12 AM
I will take a few better pics tomorrow night.
#10 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted November 20, 2012 - 08:26 AM
you should be able to just cut the condesor/points wire and put a new style coil on it
#11 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 563 posts
Posted November 20, 2012 - 08:57 AM
That is what I was hoping.
