* * * * - 2 votes
St16 *updated With Snow Blower Video*
st16 sears 16
56 replies to this topic
#16 MH81 OFFLINE
  • 29,979 Thanks
Posted November 21, 2012 - 09:21 PM
Will that old gas even burn? That is nasty.
Nice tractor.
Oh, that is long gone. And to answer your question, no it wasn't even flammable. I tried some in the fire ring out back.
#17 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted November 21, 2012 - 10:45 PM
My tank was dry but rusty and cruddy. I put in some nuts, bolts, screws, etc. and shook it and then dumped them out. Next, I took some old, oil-gas mix I had that was no longer gas. I swished that and shook it and dumped it on my brush pile. I could reach a finger into the tank and it was just full of loose wet rust. I tried a magnet and got what I could reach. This was working so well that I took my newer can of mix, about 3 years old and smells a little like gas, and poured some in. I added nuts and bolts again and shook and shook. then set it so everything would "float" to one end of the tank. Magnet again grabbing piles of metal and rust. When I picked up no more, swish, shake, tumble, magnet. Repeat, Repeat, Repeat, till the magnet found nothing. I left the liquid in there till I get fire to the plug. (Still trying to figure that out) Then I will swish and magnet one last time before giving the tank a final, fresh gas rinse.
  • MH81 and Sawdust have said thanks
#18 Hugh OFFLINE
Hugh
  • 171 Thanks
  • 171 posts
Posted November 22, 2012 - 11:49 PM
Looks good! Sounds pretty good too. In addition to the basic carb clean, I would also recommend running Sea Foam, Marvel Mystery Oil, or something similar through the engine to clean up the internals. In my experience with an OH160, 1.5 turns from seat is a good starting point for both mixture screws.
#19 MH81 OFFLINE
  • 29,979 Thanks
Posted November 23, 2012 - 09:34 PM
In my first post, I mentioned another tractor. This Sunday, I'm going over to take a closer look. I am taking the trailer, if that's any inclination of my intentions.
I'll start a different thread about it, but this one's a two cyl.
  • Sawdust said thank you
#20 KennyP ONLINE
  • 41,503 Thanks
  • 47,416 posts
Posted November 24, 2012 - 05:22 AM
And now the guessing game begins! Does that mean it has two engines on it?
#21 mjodrey OFFLINE
Posted November 24, 2012 - 07:04 AM
A two cyl. eh.Humm ???
#22 Hugh OFFLINE
Hugh
  • 171 Thanks
  • 171 posts
Posted November 24, 2012 - 12:38 PM
Onan I hope?
#23 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted November 24, 2012 - 01:33 PM
Awesome score Alan. As for the gas tank, Pea Gravel works well for that, and good old straight gas, you will want the potent stuff too. And after a lot of shaking, sloshing, rotating, spinning, and using it in a one man musical band you will be surprised how clean is gets. You will always want to rinse with more gas after emptying of pea gravel. Anyway, good luck on the next haul.
#24 MH81 OFFLINE
  • 29,979 Thanks
Posted November 24, 2012 - 02:22 PM
Onan I hope?
Yeppers, :dancingbanana:
#25 Hugh OFFLINE
Hugh
  • 171 Thanks
  • 171 posts
Posted November 29, 2012 - 10:47 PM
SS/16, SS/18, 16/6, 18/6, GT/18, GT/18H, GT/19.9, FF20, FF24?
#26 MH81 OFFLINE
  • 29,979 Thanks
Posted November 30, 2012 - 02:23 AM
I forgot to put a link in this thread to the other one.
http://gardentractor...-in-the-stable/
Thanks for reminding me Hugh
#27 MH81 OFFLINE
  • 29,979 Thanks
Posted December 02, 2012 - 08:21 PM
I've had a busy day. I had a good helper last night with KK and good help today in the rain with Ryan.
Last night KK and I did a little work on the 16, we got the 3 point all mounted up (finishing by flashlight)
Today Ryan & I remounted the old gas tank as a temporary measure, did a little rewiring, installed a replacement light switch, got the snow blower on and did some maintenance. The oil change was forced upon me as the old blower belt broke, came off the blower and promptly wrapped itself around the oil drain pipe, breaking it off at the block. Catch pan was close, but man that sucked. Stopped the engine NOW.
After finding a replacement pipe and verifying all damages were corrected, we adjusted the new belt and did a test run with it.
https://www.youtube....h?v=2sur_wKWEOs
it's short, but it was almost dark and still raining..
For some reason, the video isn't embedding right, there is a link under the video for anyone who cant see it.
#28 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted December 02, 2012 - 08:29 PM
Looks and sounds great! :thumbs: Sorry for your mishap with the pipe :( . Glad it wasn't worse!
Thanks for the video too!
#29 DH1 ONLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted December 02, 2012 - 08:30 PM
Motor sounds gooood. :thumbs:
#30 MH81 OFFLINE
  • 29,979 Thanks
Posted December 02, 2012 - 08:43 PM
It does sound good, doesn't it? :dancingbanana:
I cant believe how it runs after the crud i found in it to start with.
Also tagged with one or more of these keywords: st16, sears 16
