Disk Question.. To Be Too Heavy Or Not Too Heavy
9 replies to this topic
#1 Buggyman OFFLINE
Buggyman
  • 42 Thanks
  • 94 posts
Posted November 18, 2012 - 10:49 AM
I am looking for a disk and have looked at the King Kutter 4 1/2 ft. 3 point hitch disk. The disk weighs 400 lbs. My tractor is a 2418. I am concerned that the disk is too heavy for my tractor. Obviously because of the size the weight hangs pretty far back. I don't want to hang lots of weight on the front of my tractor just to accommodate this disk. I notice that King Kutter also has a single row pull behind disk, BUT it is $100 higher AND not adjustable. On the other hand does anyone know of another company that makes a disk of at least 4 ft. that is a better deal, works well, fits my tractor, etc.
What da ya think?
#2 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted November 18, 2012 - 11:57 AM
Look for a used Brinly 4 foot tandem disk. It will work perfectly for you.
#3 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted November 18, 2012 - 12:17 PM
Just a though. How about lifting the front of the disk with the tractor and add a ram and a swivel wheel on the back to lift it.
Weight is always you friend on a disk.
#4 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 18, 2012 - 05:54 PM
Ducky may have the best idea. you may be able to pull the disc but that is a lot of weight. the wheels carrying it would take the load off lifting the front end.
I have a 1500 Ford and a tiller around 450 lbs and it can be a bit light on the front end it will lift more but ii have too be careful how i turn on hills. I have been considering the same disc but my tractor does weigh around a ton.
Edited by JD DANNELS, November 18, 2012 - 05:57 PM.
#5 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted November 18, 2012 - 06:15 PM
But too big may be ineffective because the tractor may not get the needed traction to move it.
#6 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted November 18, 2012 - 07:27 PM
You can something like this.
#7 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 19, 2012 - 11:18 AM
The more I think about it the more I think Ducky and Amigatec have the right idea. I'm thinking a 4 ft tandem disc would pull too hard. I have seen 38"(I think) tandem wheel discs to pull behind ATV's that might work and I don't think they were higher than the King Kutter you were looking at? Amigatec, do I remeber correctly in seeing a video of you pulling your disc with the cadet? The Powerking would surely handle your set up.
#8 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted November 19, 2012 - 01:04 PM
Yes my Cub Cadet 129 pulled it just fine, this is a L38 Disc made for a Cub Tractor.
#9 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted November 19, 2012 - 01:08 PM
#10 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 20, 2012 - 09:02 AM
The cadet did very well for having turfs. That's a nice disc set up with the wheel carriers.
