Ahh Got To Spill The Beans (new Repower Engine For Bolens 1256)
101 replies to this topic
#61 olcowhand ONLINE
  • 41,095 Thanks
  • 31,402 posts
Posted March 05, 2013 - 11:48 AM
You're doing a clean job on this repower!  You will be fine on your 45 flare with these pressures.  The fittings will match the angle when you clamp them tight anyway.
#62 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted March 05, 2013 - 11:57 AM
 Double flaring is not recomended for hydraulic tubing. Especially if it has the backer sleeve , that acts as your "double"
 The rolled edge in a double flare used with 37 degree hydraulic fittings can and will crack the rolled edge . Also they put the preassure sealing point in a narrower band making it easier to develop a leak.
 As long as these joints aren't subjected to loads stressing them you should be fine.
 Also the 45 degree flare will work just fine , just make sure you tighten them good , back off and retighten.
Edited by skyrydr2, March 05, 2013 - 12:01 PM.
  • 8tyman8 said thank you
#63 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted March 05, 2013 - 01:04 PM
Thanks .. I have a erratic? 45 degree flare tool would it be fine just to do a regular fare and not use the Double flare thing ? If the School lathe was was not locked out and the (Health and safety person has ever used a lathe they would understand Why its a good idea Not to have a Ton of guards and crap set up IMO its much more dangerous as you don't have as much of a clear view of site) i would make my own ... 37 degree tool ... the only reason i double flared them is because a while back i bought a Whole bunch of Used hydraulic stuff (from Gt's) and almost Every line was double flared .. and it used the Lighter tubing (brake line) like i am using Also the lines on this were double flared Worse comes to worse i will take all the lines to a Friend at a Hydraulic shop and have lines made ... Or buy a flaring tool But i will keep that in my mind about the Pressure point contact thing ...
#64 olcowhand ONLINE
  • 41,095 Thanks
  • 31,402 posts
Posted March 05, 2013 - 03:03 PM
You should be fine with a std flare.
#65 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted March 05, 2013 - 03:30 PM
Absolutely fine doing a single flare. With the backer sleeve your not supossed to double them. The pressures are low so that isn't a worry, Its the vibrations that usually wreck them.
Edited by skyrydr2, March 05, 2013 - 03:32 PM.
#66 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted March 05, 2013 - 06:53 PM
my luck with this kubota it will shake Every bolt of the tractor LOL i can tell you one thing i will need to do Alot of pissing around to get all the Squeaks and squawks out of the sheet metal ...
#67 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted March 05, 2013 - 07:49 PM
LOL no doubt.
#68 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted March 07, 2013 - 02:27 PM
All the Hydraulics are done ... Now its just waiting on parts to arrive.  Also next week is March break If the parts were here i would bring it home and work on it .. but they are not .. Also am might be getting a New PTO shaft .. and i need to Practice Welding for the Skills Ontario competition.. Will post some pictures of the Beads i have been laying down ... May start a new thread on it
Cheers
Ty
#69 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted March 22, 2013 - 02:41 PM
Got the linkages done and some brackets made fixed the fuel tank (the spout was Way to long and the cap did not thread on) got the Right new oil filter after i found out that carrier has a standard thread for the oil filter i also ordered a spin on fuel filter head and am going to use a napa 3390 filter i also worked on the dash i am reusing a dash from my 750 that has Tones of holes drilled into it (going to Tig weld the holes) also upgraded the Throttle to the lever type
  • twostep said thank you
#70 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted April 05, 2013 - 02:37 PM
So i have been busy with this project my Plan was to have it running for a Test run on Thursday but Nothing goes to plan the Fuel pump was Defective ... and did NOTHING Up to this point i had every thing ready for a Test run/Drive (most importantly the drive)  and that there is no Conflicts so the electrical is Make it Run done and every thing else is done for the drive fuel hydraulics and on .... the Muffler,Seat,lights,gauges,hood and pto(and all the belts) still need to be finished then its Finishing Touches and Very minor things but its still a work in-progress
  • HowardsMF155, boyscout862 and twostep have said thanks
#71 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted April 15, 2013 - 03:44 PM
New fuel pump .. i am in the process of rebuilding the seat and mount More to come tomorrow
#72 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted April 16, 2013 - 06:11 PM
Got the seat mount made its 2 way so you can flip the seat around (Backhoe..) Rebuilt the seat and recovered it Looks pretty good but the fuel pump and started it ... And in 5-10 minutes the temp went to 180-200F And the rad will still cold .... took the to hose off and it just dripped at 1/2 throttle ... pulled the water pump and it was Nasty should have it figured out tomorrow ...
#73 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted April 18, 2013 - 03:58 PM
Got it running (Video will be up soon ) ran some cooling system flush stuff thru it and it ran 140 F all day (2 hours ) Can't seem to get any smoke tho Does any one know how to turn the injecton pump up a little ? Just a little ...
Cheers
Ty
#74 twostep OFFLINE
twostep
    Rockstar
  • 1,984 Thanks
  • 2,535 posts
Posted April 18, 2013 - 04:15 PM
Looks pretty good, can't help you with the smoke thing... that is what I love best about my diesel, it's efficient!
#75 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted April 18, 2013 - 04:31 PM
on the front gear cover near the throttle linkage there is a tin cap covering a nut. remove the tin cap and the outer nut. loosen the jam nut and turn out the screw with a screwdriver a little at a time. She will smoke! You'll see what im talking about when you look at it
