Ahh Got To Spill The Beans (new Repower Engine For Bolens 1256)
101 replies to this topic
#46 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted February 06, 2013 - 02:49 PM
Some pictures
  • twostep and larryd have said thanks
#47 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted February 11, 2013 - 02:50 PM
got back to school .. i got the valve and levers figured out ... and i got the first bracket made for the aux hydraulic couplers next thing i need to do is rebuild the travel petal as some one DESTROYED it there is a Massive bend in it and the the bushings are gone so i have 2 new bushings to put in it and they might be grease-able also i need to extend the rear Tool box to fit a custom fuel tank
  • twostep said thank you
#48 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted February 14, 2013 - 08:39 PM
Its time to play Everyone LEAST FAVORITE GAME ............. guess that part ! i will post what its for tomorrow once its mounted !
Heres the hint It will bolt under the tool box on a bolens Hydro it mounted to the Rear of the tractor One has not been made for the tubeframe series the bore is 1" and it is HEAVY Plate ....
(ps i was Not drunk when i welded that i grabbed 308L ss rod as the tube is ss and i wanted to Try to weld stainless to steel there was alot of porosity from the Zinc So i might re make this "part" and use 7018 and really grind it down ... if you are wondering it was welded Out side in the wind
Edited by 8tyman8, February 14, 2013 - 08:43 PM.
#49 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted February 15, 2013 - 02:18 PM
so the answer is a independent limited Cat 0 3 point that is part of the bracket for the rock shaft and top link got the tool box extended for the fuel tank now i need to get the tank made ..I also got the Front fittings mounted next thing on the list is so get the rear fittings installed and then lines and maybe start work on the Pto . i am going with pillow block bearings they should be going on sale on the 18-19th of the month i also need to get the cylinder mounted for the rock shaft and make sure nothing is going to intercomingle also need to get the air cleaner mounted muffler .. and on and i need to work on a larger Hydraulic tank im shooting for 2L as i want to build a dump trailer .. some day  im thinking of mounting the resivor under the battery .. as there is Alot of waster space under that hood Atm it will be nice to drive this thing around :)
#50 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted February 15, 2013 - 03:58 PM
Looking good so far!  I've been following, but often forget to comment.
#51 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted February 20, 2013 - 03:03 PM
The Pto I have Stole Cake's (over on Mtf) idea using the pillow block bearings how ever my bearing assembly will be bolted on not welded ... the pipe happens to be from a lawn mower handle I think it should be able to take the torque as the h14lx hydro drive shaft is made out of the same pipe ... if it breaks then i will get one made the pto shaft is some what Junk before is started this (the splines are pretty bad) how ever i plan the cut a keyway and use a 5/8 pulley with set screws to run this now down to the nitty gritty the handle was .7490 the shaft was .7495 (clearance for bearings ) that thing just fit nicely after i tapped it in there with a hammer i tacked the one end so i could press in the other end i will tig weld it once back to school tomorrow it runs quite true for a back yard made unit i would say we are running with in 2-4 thousands
cheers
Ty
#52 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted February 21, 2013 - 02:31 PM
Got some more work done and well i was welding the new and inproved hydro petal bushing mount things on the 40 year old grease lit fire for a few seconds ! Luckily i had some one there to pour some water on it ! its not welded on the greatest (Mig) once i get it home i should be able to use the stick welder and finish it up (on the top with a J shaped Electrode) also got the Air cleaner mounted and in place the bracket will also be part of the Pto belt guide its getting tight under the hood ! i do plan to used a Honda civic battery Small size and Larger CCA i also left room be-twine the air cleaner and the Frost plug In-case i go with a Block heater
Edited by 8tyman8, February 21, 2013 - 02:32 PM.
#53 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted February 26, 2013 - 02:44 PM
some paint and Hydraulics .. the Fuel tank is also done .. Tomorrow i think i will be working on the Hydraulic/trans Tank
  • tractorgarden and twostep have said thanks
#54 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted February 26, 2013 - 08:05 PM
It is coming along rather well. Keep up the good work!
#55 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted March 01, 2013 - 02:24 PM
made some Fuel and Hydraulic fluid Tanks out Stainless steel also got the Filter mounted also some little things.. Monday i plan to get All the Hydraulic lines in then the Fuel lines Up to the Engine .. it looked like the Fuel pump i had was going to work but its not .. so i think i will need to go Electric .. a pumps is like a $100 :( Would one of the Pulse type pumps that run of Crank case pressure work ?  Also how does the fuel flow when cold (-20C-4F)
#56 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted March 04, 2013 - 02:02 PM
Fuel / hydraulic lines ..
#57 skyrydr2 ONLINE
  • 3,870 Thanks
  • 3,403 posts
Posted March 04, 2013 - 02:25 PM
 AWSOME JOB !!!
#58 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted March 04, 2013 - 05:28 PM
 AWSOME JOB !!!
Thanks .. I sure like the Steel lines How ever probably should of got the Actual Hydraulic line instead of using Brake line I have access to a whole bunch of Swage-loc ss line with .045 wall but i can't flare it :( for the Jic fittings so any line i could do in swage loc i did I uno i just like the Look of Steel lines (judging they are correct) And the factor that they Will some what Radiate heat .. also last WAY longer than rubber and they are cheaper ...
Cheers
Ty
#59 skyrydr2 ONLINE
  • 3,870 Thanks
  • 3,403 posts
Posted March 05, 2013 - 04:35 AM
 Yup You ain't flarin' them with a standard flaring tool ! You need the one needed for hydraulic tubing , it has rollers that "roll" the flare into the tube against the "die" . And the tool must be held in a rugged vise to do this. I have a few differerent sets, they are very $$$$ .
#60 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted March 05, 2013 - 10:17 AM
:l Yes your right .... I am Double flaring them with regular one Iv done it in the past with good results .. I know its not right to use a 45degree one on a 37degree fitting but thats all i currently have to work with Also its not like a 4-5 thousand pound line ... im working with maximum 500 i do plan to buy a Ridgid 377 but the budget is to small for one now The funny thing is one of the Factory hydraulic lines Appears to of been flared with a 45degree double flare tool ...
