Ahh Got To Spill The Beans (new Repower Engine For Bolens 1256)
101 replies to this topic
#31 mjodrey OFFLINE
Posted January 12, 2013 - 07:19 AM
That is coming right along. :thumbs:
#32 olcowhand ONLINE
  • 42,413 Thanks
  • 31,806 posts
Posted January 13, 2013 - 04:07 PM
Looking good so far!  Looks like it will be a great unit when finished.
#33 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted January 16, 2013 - 06:46 PM
Got some more stuff done got the mounts made and tack welded i got the new axle on (larger spindles and its Tight) i got the steering linkage extended and put on the Right Direction so now it steers proper i picked up a radiator with a LARGE FAN hoping it will work i have the 37 amp alternator so it should work with the big fan the rad is nice shape with straight fins its only one pass tho i hope it works its Aprox 15x18" so tomorrow i need to get the rad mounts and lines ran and then finish some welds then a "Test Run"
Cheers
Ty
  • twostep said thank you
#34 jim knutson OFFLINE
jim knutson
  • 66 Thanks
  • 136 posts
Posted January 16, 2013 - 07:59 PM
i love your add on decals..... :bigrofl:
#35 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted January 17, 2013 - 02:15 PM
The rad is in ! tomorrow i plan to fill it with fluids finish up the mounts and start it ! will try to get a video !
  • olcowhand and twostep have said thanks
#36 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted January 18, 2013 - 03:39 PM
It runs
the rad was leaking so i got it swapped out with no issues Thanks european auto parts my custom oil pan has a Drip appears to be coming from the bolt i think its that the cork gasket is not Compressed as you can see by the video it runs Strong i just ran water in it got it up to temp and the thermostat opened i did not try running it with the fan but after i shut it off i ran the fan quick and it cooled the rad down Quite a bit it took some work to blead the injectors as there is currently no fuel pump but that is some thing i need to order soon
#37 olcowhand ONLINE
  • 42,413 Thanks
  • 31,806 posts
Posted January 18, 2013 - 03:56 PM
Sounding great!
#38 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted January 18, 2013 - 04:14 PM
Sounding great!
it sounded better after it Warmed up i thought it would have more Fuel knocking but it sounded better than the gas engine
#39 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted January 18, 2013 - 04:20 PM
That's awesome! I just got up to speed on your build and you are doing a great job! :thumbs:
The diesel sounds great to, and thanks for the video! Good luck :D
#40 Cvans ONLINE
  • 7,089 Thanks
  • 6,297 posts
Posted January 18, 2013 - 07:59 PM
Isn't it a great feeling when you finally get to start it up and it runs good!   :D   Sounds nice and seems to be smooth.
Looks like your well on your way to having a driving tractor. I also like the idea that your were able to install the radiator
in front. That in itself is somewhat unusual. Thanks for updating us.
#41 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted January 22, 2013 - 03:11 PM
Got a new rad ! and some other stuff i need to get a Fuel pump/filter and a cummins fuel stop solenoid as i can get them at the wreckers i got the oil leak fixed and got new pulley's
Thats all for now !
cheers
Ty
  • Cvans and twostep have said thanks
#42 twostep OFFLINE
twostep
    Rockstar
  • 1,987 Thanks
  • 2,538 posts
Posted January 23, 2013 - 11:03 PM
Your build looks great! nice job on making it fit. I've got a Z500 in my kubota and cant speak highly enough about it. Fuel sipper very strong and reliable. My kubota is gravity fed to the injector pump and the one time I've run it out I tried and tried to get the fuel to pump through. Finally I checked my manual and found out that there is a bleeder screw right where the fuel line comes in (see pic). After I loosened that up and fuel started seeping out I closed it and it fired right up.
Couple of questions and I appologize if I missed this info:
How do you plan to extend the hood.
What are dimensions on that radiator? It looks plenty big to keep it cool.
Would an oil pan from a Z500 engine fit?
  • 8tyman8 said thank you
#43 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted January 24, 2013 - 09:29 AM
Thanks for the info on the bleeder screw ! this engine is the First Diesel i have owned ! and i am Very impressed on the Quality and set up !
The hood i will use 14-16 gauge metal and bend it with a pipe and vice then flange the edge and tig weld it !
the radiator is 15x16 (core size) and looks like a 2 core it has a Big fan that draws 6 amps
and the Z series Do exchange parts ... i called my local kubota dealer and inquired about a oil pan with no response so i made one .. cost me about 6 Bucks to make and bolt on ...also the old oil pan is off is any one is looking for one its the big one so yes the oil pan should fit .. as there is Many oil pan options ..
cheers
Ty
Edited by 8tyman8, January 27, 2013 - 10:48 PM.
#44 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted January 26, 2013 - 09:04 PM
I have a Slight Problem ! the Pto shaft and pulley is Messed up !
IMG_0112.JPG see how there is no key way and its round ! the splines are Gone !
also the shaft is To short ! by 6" should i go to a Machine shop and get them to cut it with a index head and a horizontal mill ? or should i get some round stock 1 1/8 bore it out on the lathe to ( .7495) a heat/press fit then cut the old shaft to length so it fits in the larger round stock tig weld then machine it down ? and make the new housing ? with 1 7/8 Id pipe with caps in the end for bearings 6203-3/4 ?
iuno i think i might need a new pulley tho
#45 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted February 05, 2013 - 02:24 PM
Today consisted of removing the seat and tin as well as removing All the hydraulic lines and the drive shaft then i pulled the hydro to drain all the old fluid out i also rebuilt the lift Cylinder as it was Leaking BAD i cleaned every thing up and blasted some parts with paint then i pulled the hydro out and used the parts washer i got all the dirt and grunge off ... if you see the pictures you may notice it says 11 the hydro has been Up graded Before i got it ! honestly this tractor does not Add up the engine was replaced with a 1988 Tra 12d the dash has the pull type knob holes but i looks like some one used a mill or jigsaw with a file and put the lever style controls and the hydro is upgraded Also the steering wheel is newer and so is other stuff ... well i will keep pushing on .. tomorrow i plan to put the new bearing in and the hydro back in i will also put the fuel pump on the engine and maybe work on the second Hydraulic valve install
