Tire Pressure
6 replies to this topic
#1 Grumpy ONLINE
Grumpy
  • 721 Thanks
  • 617 posts
Posted November 17, 2012 - 03:54 PM
What air pressure do you run in your rear tires when plowing?
#2 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted December 10, 2012 - 01:55 AM
on the walk-behind i only run 3 -5 lbs, just enough to keep the tire on the rim.
#3 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted December 10, 2012 - 07:42 AM
On the JD140H3 with unloaded 23 X 10.50 -12 ags on 9.5" rims with 90# weights on each side and a 250# operator I run 10 PSI all the time.
#4 HowardsMF155 ONLINE
  • 2,861 Thanks
  • 2,987 posts
Posted December 10, 2012 - 09:27 AM
My massey tractor specs 5 - 7 psi in the rear tire, on the one I'm plowing with I have it at 5 psi.
#5 twostep OFFLINE
twostep
    Rockstar
  • 1,984 Thanks
  • 2,535 posts
Posted December 19, 2012 - 06:27 PM
I run 6 in mine all the time... mowing, plowing, whatever.
#6 olcowhand ONLINE
  • 41,086 Thanks
  • 31,402 posts
Posted December 19, 2012 - 07:07 PM
10 to 12psi with fluid filled.
#7 CubMan70 OFFLINE
CubMan70
  • 2 Thanks
  • 3 posts
Posted December 30, 2012 - 09:07 AM
Yeah I got 23-8.50x12 fluid filled with two ih weights
