How To Clean Up Galvanized Parts?
7 replies to this topic
#1 IamSherwood OFFLINE
  • 8,390 Thanks
Posted November 16, 2012 - 07:46 AM
Does something like CLR work?
#2 MH81 OFFLINE
Posted November 16, 2012 - 08:26 AM
Will, is it rust, paint, grease or? that you're trying to remove? Also, are you trying to keep the galvanizing?
#3 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted November 16, 2012 - 08:44 AM
I have used a weak solution of muriatic acid. You dip or spray the part in a 20:1 water to acid ratio, but just for 3 to 4 seconds at a time, then immediately flush with plenty of water to stop the acidic action. It will remove a slight film of zinc, but leave it looking like fresh galvanize.
Usually one or 2 times does the trick.
  • daytime dave, Alc, IamSherwood and 2 others have said thanks
#4 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted November 16, 2012 - 10:15 AM
Vinegar will clean galvanized metal. Plus it's fairly safe to use.
  • daytime dave, Alc, IamSherwood and 1 other said thanks
#5 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,189 Thanks
  • 5,666 posts
Posted November 16, 2012 - 01:44 PM
Yes- The PH of white distilled Vinegar (Acetic acid parent) is ~ 2.4 while the PH of 10% Muriatic is ~ -0.5..
The Muriatic acid is much stronger and the hazards presented by it much greater. (Hydrochloric acid parent)
So I'd try the vinegar first and see if it works.. Good luck!
  • daytime dave, IamSherwood and Cat385B have said thanks
#6 IamSherwood OFFLINE
  • 8,390 Thanks
Posted November 19, 2012 - 10:49 AM
Thanks guys.
The parts are the linkage rods for the brakes, and gearshifts on the Elf.
They are just looking a bit dull(tired).
I will try the vinegar. Acid scares me.
#7 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,189 Thanks
  • 5,666 posts
Posted November 19, 2012 - 12:08 PM
Thanks guys.
Look what it did for Timothy Leary!! :loosing_it: :reading_the_manual:
Sorry- Couldn't resist!! :D
  • IamSherwood said thank you
#8 tinner OFFLINE
tinner
  • 503 Thanks
  • 1,561 posts
Posted November 20, 2012 - 12:17 AM
In the shop we would etch galvanized metal with vinegar before painting. Works great to both clean and etch.
