the 212 just died on me...
22 replies to this topic
#16 olcowhand ONLINE
  • 40,374 Thanks
  • 31,177 posts
Posted August 18, 2010 - 07:06 PM
all this stuff is before me lol I'm the EFI generation :)
I'd say so, as your pic in your avatar clearly shows! :rolling:
#17 brzezinski01 OFFLINE
brzezinski01
  • 4 Thanks
  • 73 posts
Posted August 18, 2010 - 07:11 PM
:smile1: LOL thanks I needed that! it's been a rough day!
#18 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted August 18, 2010 - 09:09 PM
We all have rough days, welcome aboard.
Listen to Dan and do what he says. Basic Trouble Shooting.
If you have an ESI system (no points) and test light does not flash as you turn the motor over there may be a problem with the internal coils.
Ask questions and we will find the issue. I like test results = VOLT - AMP - OHM readings and then we can come to the problem and fix.
#19 custom8mm98 OFFLINE
custom8mm98
  • 1 Thanks
  • 60 posts
Posted August 22, 2010 - 07:11 PM
change the condensor its a cheap fix and im willing to bet its the problem. ive seen it more then once being the problem and they are less then $5 at any parts store.
  • brzezinski01 said thank you
#20 brzezinski01 OFFLINE
brzezinski01
  • 4 Thanks
  • 73 posts
Posted August 30, 2010 - 07:13 PM
Thanks to everyone that helped! I got her running again tonight, I had to put both the coil and condenser, but she started up nice and runs like before. Thanks again everyone!
  • NUTNDUN said thank you
#21 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted August 31, 2010 - 05:13 AM
Good job, glad to see you got her running again.
#22 srtbrew OFFLINE
srtbrew
  • 4 posts
Posted October 13, 2010 - 07:12 PM
My thoughts exactly.
#23 Mikeemc OFFLINE
Mikeemc
  • 1 Thanks
  • 17 posts
Posted October 16, 2010 - 01:39 PM
Good to see you have her running. When I got mine I had a wire spider and bad ignition.
