M23 Belt
6 replies to this topic
#1 speedyx OFFLINE
speedyx
  • 8 Thanks
  • 43 posts
Posted November 15, 2012 - 08:19 AM
Hello out there in Speedx land, any one have idea of belt size on this tractor? All the hide is worn off mine. Thanks
#2 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted December 11, 2012 - 11:22 AM
Seeing as you don't have any replies on this thread yet...... You might have to end up measuring the one you have and subtract a little for stretching.Or you can get some adjustable belt http://www.johnstone...rodW89-316.html and adjust to the length you need,measure it,and buy a new belt. I usually keep some adjustable belt around for measuring lengths cause I always have something nobody has any information on and I need a belt for it.
  • speedyx said thank you
#3 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted December 11, 2012 - 11:36 AM
Sorry I can't help you with a belt either but what I do is I have assorted old belts collected through the years and when I'm trying to get one of an unknown like yourself I'll take one that my be the correct width but say too long , cut it to fit the best I can , then take the belt to an auto parts store that has a belt gauge and they can uaslly figure out what I'll need , Al
#4 speedyx OFFLINE
speedyx
  • 8 Thanks
  • 43 posts
Posted December 13, 2012 - 09:28 PM
That was my next option using the belt gauge.
#5 DougT OFFLINE
DougT
    Dog Approved
  • 6,926 Thanks
  • 4,994 posts
Posted December 14, 2012 - 02:33 PM
The width of the pulley near the top should give you that dimension. Then if you can find a piece of rope about that diameter, wrap the rope around the pulleys and measure it. you can mark the old belt and use a tape measure around it too but sometimes the width seems to change that measurement on a worn out belt.
#6 Guest_gravely-power_*
  • Guests
Posted December 14, 2012 - 03:22 PM
This will work.
http://www.wisc-onli...spx?ID=ENG21906
#7 speedyx OFFLINE
speedyx
  • 8 Thanks
  • 43 posts
Posted December 27, 2012 - 09:19 PM
Thanks guys I guess I was doing it the hard way
