Bada Pocket Turbo 130 Mig Welder - Wire Feed Rate Issues
16 replies to this topic
  • 2,254 Thanks
  • 1,464 posts
Posted November 12, 2012 - 06:23 PM
In August, my brother-in-law dropped off his spare welder so I could learn to weld. At least that's what he said, just before he mentioned it wasn't working & hit the road. I had never welded before so I thought, What the h..., I'll try to fix anything.
A visual inspection revealed that the brown and white wire was not connected to anything. I put the lug on the end and connected it to the terminal it is now connected to, mostly because that seemed to be a terminal it would reach.
My problem is that the wire feed rate seems to be to fast. It welds beautify if I turn the wire feed rate to the lowest setting. If I turn it up, it sputters & leaves big blobs with no penetration.
Anyone have a similar welder and / or know where the brown & white wire goes?
#2 marlboro180 OFFLINE
marlboro180
  • 634 Thanks
  • 954 posts
Posted November 13, 2012 - 01:02 AM
It's a 130 low power welder, of course it's gonna spruuter at a decent rate LOL :-) Sorry, being a smarty pants here... ( hiding now lol)
Edited by marlboro180, November 13, 2012 - 01:03 AM.
#3 KC9KAS ONLINE
KC9KAS
  • 4,887 Thanks
  • 4,356 posts
Posted November 13, 2012 - 05:17 AM
Have you tried to go "online" to find a manual for this welder or maybe a wiring diagram?
Do you have "gas", or is it flux core wire? Has the wire gotten wet? Just trying to come up with a logical answer!
#4 New.Canadian.DB.Owner OFFLINE
  • 2,254 Thanks
  • 1,464 posts
Posted November 13, 2012 - 07:41 AM
Yes, the Internet was my first stop. I can't even find a photo of the welder, let alone a manual. I'm using a new role of flux core wire (without gas).
I was hoping that someone might say "Hey, that's my welder only mine was made by ..."
#5 marlboro180 OFFLINE
marlboro180
  • 634 Thanks
  • 954 posts
Posted November 13, 2012 - 11:37 AM
Try looking around for a Cebora manual, that welder sure looks the same, Italian, I believe.
As to the placement of that brown / white wire, I haven't a clue.
What kind of feed rate are we looking at in inches per minute when the trigger is pulled though? A general idea is that one pulls the trigger for 10 sec, measure the amount of wire laying out, and multiply by six. That's your IPM rate. Then compare that to a chart, such as this one:
http://www.millerwel..._calculator.php
The thickness of materials, gauge of the welding wire, stickout, and input voltage capacity will all affect the weld, including those infuriating blobs.
Edited by marlboro180, November 13, 2012 - 11:40 AM.
  • Alc and New.Canadian.DB.Owner have said thanks
#6 KC9KAS ONLINE
KC9KAS
  • 4,887 Thanks
  • 4,356 posts
Posted November 13, 2012 - 04:49 PM
Try here.........http://www.mig-welding.co.uk/manuals.htm
#7 New.Canadian.DB.Owner OFFLINE
  • 2,254 Thanks
  • 1,464 posts
Posted November 14, 2012 - 07:32 PM
Well, that was helpful if not sole destroying. Turns out the welder is wired correctly and I suck at welding. Guess I need more practice.
BTW the Bada Pocket Turbo 130 is wired more like picture b of the Cebora MIG 140 (Art 848) than like the Cebora Pocket Turbo 130 (Art 886).
#8 marlboro180 OFFLINE
marlboro180
  • 634 Thanks
  • 954 posts
Posted November 14, 2012 - 11:43 PM
Naww, not soul destroying, just means ya gatta learn some.... No biggie. I am self taught, well, kinda.
Glad the Cebora link helped you out a bit. My first clue was " Imported / Fabrique " for " Bada" , they had links to to Europe...and the Telex nimeber showed zippo....
I think Snap - On sold those here a while back too, in the U. S. A. ???
Edited by marlboro180, November 14, 2012 - 11:48 PM.
#9 KC9KAS ONLINE
KC9KAS
  • 4,887 Thanks
  • 4,356 posts
Posted November 15, 2012 - 05:00 AM
Try this:.......Anti-Spatter Spray 16 oz. by Firepower (part#FPW1440-0296) / Welding Tools & Accessories
#10 New.Canadian.DB.Owner OFFLINE
  • 2,254 Thanks
  • 1,464 posts
Posted November 17, 2012 - 07:11 PM
... What kind of feed rate are we looking at in inches per minute when the trigger is pulled though? A general idea is that one pulls the trigger for 10 sec, measure the amount of wire laying out, and multiply by six. That's your IPM rate. Then compare that to a chart, such as this one:
Well, I seem to relearn this lesson far to often: "wired correctly" does not mean the same as "functioning correctly". I went out today to compare feed rates like marlboro180 suggested. I noticed the motor speed doesn't actual change for 99% of the range. The bottom 1% drops the speed from flat out to near stopped. Guess I need to repair or replace the controller board.
#11 marlboro180 OFFLINE
marlboro180
  • 634 Thanks
  • 954 posts
Posted November 17, 2012 - 11:55 PM
Yes, I hear that, even my multi- gizmotor Thermal- Arc machine does not always like to spit out the same IPM,,,, Though it is usually kinda close, ( usually crud in the line, or feed rollers ).... not like what you are describing.
#12 New.Canadian.DB.Owner OFFLINE
  • 2,254 Thanks
  • 1,464 posts
Posted November 20, 2012 - 06:20 PM
Found the (current) problem. Bad solder joint on the speed potentiometer. Now I just need something to weld ...
  • marlboro180 said thank you
#13 Alc OFFLINE
  • 5,643 Thanks
  • 6,736 posts
Posted November 20, 2012 - 06:57 PM
Glad to hear you found your problem :thumbs:
Al
#14 KennyP OFFLINE
  • 29,459 Thanks
  • 40,433 posts
Posted November 20, 2012 - 07:03 PM
Glad you could figure it out. I would have used the mig to weld it up. :bigrofl:
To put it bluntly, my electronic skills SUCK!
#15 marlboro180 OFFLINE
marlboro180
  • 634 Thanks
  • 954 posts
Posted November 20, 2012 - 10:57 PM
SO , just what scematic / manual did ya find that in?
Cool beans, and nice work. Come on over, I got plenty of stuff to weld on LOL....
