Brinly Plow Share
73 replies to this topic
#31 olcowhand ONLINE
  • 42,399 Thanks
  • 31,803 posts
Posted January 11, 2013 - 07:29 PM
Does Fred know you stole his tranny?
Not yet!  :bigrofl:
#32 Robert Webb OFFLINE
Robert Webb
  • 923 Thanks
  • 435 posts
Posted January 12, 2013 - 02:42 PM
Well if everything goes according to plan, I am going to be looking at building a 2 bottom to use this year!  I have a couple of ideas on how to build it so we shall see what happens.............need to find a couple of Brinly 10" plows.....maybe even a third one.
#33 olcowhand ONLINE
  • 42,399 Thanks
  • 31,803 posts
Posted January 12, 2013 - 02:45 PM
A 3rd one!!!   You better weight down that 430 REAL good!  You better start eating a lot of snack products (for belly ballast)if you know where you can lay your hands on some!
#34 Robert Webb OFFLINE
Robert Webb
  • 923 Thanks
  • 435 posts
Posted January 12, 2013 - 08:55 PM
430????????  I cant afford one of those..................lol
#35 olcowhand ONLINE
  • 42,399 Thanks
  • 31,803 posts
Posted January 12, 2013 - 09:20 PM
JD400 then?  I have trouble remembering.  I guess you're on Drew's 430 in this pic then?
#36 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted January 13, 2013 - 08:22 AM
I have a question about plows. I have a Sears 3-point plow, 8", 917.253010. If I could find another 8" plow, do you think this would make a good 2 bottom for the Ford or FF20? I'm not beyond modifying it. if you all think it would work.
#37 olcowhand ONLINE
  • 42,399 Thanks
  • 31,803 posts
Posted January 13, 2013 - 08:46 AM
It will pull the twin 8's with ease and the Sears 8" plows are built plenty stout.  I say go for it!  :thumbs:
#38 HowardsMF155 ONLINE
  • 2,885 Thanks
  • 2,996 posts
Posted January 13, 2013 - 08:52 AM
Down side is that a moldboard is supposed to run half as deep as it is wide.  So, in theory, an 8 should run 4 deep, a ten should run 5, and a 12 should run 6.  Anybody ever been able to put a full size 14 on one of these powerful little garden tractors?
#39 olcowhand ONLINE
  • 42,399 Thanks
  • 31,803 posts
Posted January 13, 2013 - 08:54 AM
Yes, so the FF may pull three 8" plows with ease.  As to the 14", I've not seen it done, but would like to attempt it!  Likely I never will though....money & time constraints.
#40 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted January 13, 2013 - 09:04 AM
Guess I'm on the hunt for another 8" plow then. I'll probably need one of your wheels to put on the back, too. But that will have to wait a bit. I have a line on another FF20, without an engine. But it has the deck and 3-point on it.
#41 Robert Webb OFFLINE
Robert Webb
  • 923 Thanks
  • 435 posts
Posted January 13, 2013 - 05:34 PM
Daniel..........that was definitely Drew's 430....lol  Seems like every plow day we go to, we always seem to play tractor swap.  lol
I saw a 6 bottom "Flip plow" while I was at my aunts house a few weeks ago and spent about an hour out there taking pictures and writing down dimensions.  It is a very simple design that I have been thinking about trying to duplicate but leaving out the "flip" part.  Dont think my 400 would handle a 6 bottom but I think the way that one was made, I could mount 3 10" plows and make it work.  It would be relatively simple to narrow up the "bite" on the plows if I couldnt plow a full 10" with each plow.  Even if I had to adjust it down to only cutting 24" wide, you have to admit a three bottom behind a garden tractor would look cool!
Just in the "planning" stages at the moment...........
#42 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted January 13, 2013 - 05:45 PM
Robert, I'm thinking about a 2-bottom setup for mine. And I've never plowed before!
  • twostep said thank you
#43 Robert Webb OFFLINE
Robert Webb
  • 923 Thanks
  • 435 posts
Posted January 13, 2013 - 05:56 PM
as long as you have the weight and HP under the hood, you should be fine.  There is a guy from Ohio that brought his down to Alabama a year or so ago and several of the guys had a chance to pull his 2 bottom 12" plow.  One of the guys pulled it with a 20HP Magnum powered 318 but it was all that machine wanted.  Several of the guys with 430s pulled it just fine.
I have several implements in mind for mine..................if for nothing else but just to say "I have one of those for my GT".....lol
#44 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted January 13, 2013 - 06:04 PM
I will probably only have 8" plows to start with. If that works good, I may try a 3-bottom! I have a 20 HP FF to pull it with.
#45 twostep OFFLINE
twostep
    Rockstar
  • 1,987 Thanks
  • 2,538 posts
Posted January 14, 2013 - 12:07 PM
Go big or stay home! I like you way of thinking Kenny!
