D Series Hydro Motor Reassemble Vid Part1
d series hydro transmission c series
4 replies to this topic
#1 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted November 12, 2012 - 06:47 AM
Finally! I had a chance to get back out to the shop and get the hydro motor back together. I had taken apart in previous vid and I had to stop when it came time to press the shaft out. I tried getting it out without a press and i buggered up the locking mechanism. I got the parts to repair that and I start the reassembly of the motor.
In this vid i show how to install the locking mech, lapp the valve plate, lapp the cylinder block, the differenecs between a standard 15 series motor and the WH motors, and clean up a little.
This motor will work on the D series and C series.
I hope it helps a few people.
  • olcowhand, ducky and Arti have said thanks
#2 KennyP ONLINE
  • 37,439 Thanks
  • 45,468 posts
Posted November 12, 2012 - 07:18 AM
What GT/hydro does this fit?
#3 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted November 12, 2012 - 12:51 PM
Wheel horse c and d series. The unit is a slightly modified Sundstrand 15 series. If you open up a regular sundstrand 15, you will see alot of the same parts
#4 KennyP ONLINE
  • 37,439 Thanks
  • 45,468 posts
Posted November 12, 2012 - 04:09 PM
I'm not a WH guru, so was wondering what the C & D Series meant. This could be very good info for some folks. Thanks for taking the time to do the video.
#5 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted November 12, 2012 - 07:22 PM
D series would be the WH D160, D180, D200
C series would be the WH c 120, c160 family
Also tagged with one or more of these keywords: d series, hydro, transmission, c series
