Sears Cat 0 3 Point Plow
3 replies to this topic
#1 rslhays OFFLINE
rslhays
  • 1 posts
Posted November 08, 2012 - 08:10 PM
are sears implements the same as cat 0 , I have an koplin 3 point electric cat 0 will an older sears plow work ?
#2 Cat385B OFFLINE
    HAZMAT CAT
  • 14,458 Thanks
  • 10,184 posts
Posted November 08, 2012 - 08:36 PM
Original Sears 3 point attachments are narrower than a standard Cat 0 three point. The spacing of the lower lift arms are 12" on Sears implements, whereas 'standard' is 20".
Edited by Cat385B, November 08, 2012 - 08:43 PM.
#3 OldBuzzard ONLINE
OldBuzzard
  • 7,127 Thanks
  • 4,824 posts
Posted November 08, 2012 - 09:10 PM
I think that it would depend on your particular 3-pt.
If the lift arms will swing in far enough it would work. That 20" number is the MAXIMUM distance at the lift arm. I don't think that there is a minimum.
#4 MH81 OFFLINE
  • 29,979 Thanks
Posted November 08, 2012 - 09:27 PM
Most guys have gotten them to work at least well enough to use, but many of them have been turned into unique yard art pretzels by being attached to much larger tractors and catching something.
