1983 Case 448 Tractor
case 448 ingersoll onan
49 replies to this topic
#16 daytime dave ONLINE
  • 4,835 Thanks
  • 6,541 posts
Posted November 08, 2012 - 09:28 PM
Congratulations on your new Case. Nothing against the Sears products you were looking at, but I think you picked the winner there. I hope you got a good deal.
  • jadefox said thank you
#17 Cat385B OFFLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted November 08, 2012 - 09:37 PM
That is our new barn! Honestly, the barn almost sold the house. More pics to come. Thanks for the heads up on Brian.
There is no absolutely no limit on old barn/shed photos. Really. 20 is good round number, imo.
#18 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted November 08, 2012 - 10:47 PM
I thin k you are right Cat, especially if it like the Dr. Suess barn down the road from you. :thumbs:
20 ish is a good round number. :D
#19 MH81 OFFLINE
Posted November 09, 2012 - 07:31 AM
Very glad you got the tractor that should suit your needs best.
I wish i could be of some assistance on the carb issue, but what I know about ONANS would just about fill your average thimble.
Oh, and I will second the above post about using carb cleaner to look for leaks.
#20 jadefox OFFLINE
jadefox
  • 15 Thanks
  • 49 posts
Posted November 09, 2012 - 07:42 AM
Going to change the oil today and use the carb cleaner to look for leaks...oh, and snap some shots of the barn :-)
#21 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted November 09, 2012 - 08:00 AM
The hunting issue could also be the governor spring is in the wrong hole/misadjusted. Here is a link to the Service manual on this engine.
  • marlboro180 and jadefox have said thanks
#22 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted November 09, 2012 - 10:10 AM
That's a good thought about the governor spring Ken . ^^^ That link to the manual should help the OP out a lot too. Thanks!
#23 jadefox OFFLINE
jadefox
  • 15 Thanks
  • 49 posts
Posted November 10, 2012 - 08:36 AM
I have not addressed the the governor spring yet, because I want to print out the service manual first (Thanks for that, Ken!). We still don't have Internet in the new house. :-(
So I had the tractor out running it around the property today. What I'm finding is that a little ways into a session of continuous driving, it begins to lose power. Give it a litte choke, and it pops right back to full power. Sound familiar?
Oh! And here's an exterior barn shot:
  • KennyP, sacsr, marlboro180 and 1 other said thanks
#24 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted November 10, 2012 - 08:57 AM
I'd love to have that barn. That is cool!
Sounds like it's running lean after a bit.
#25 jadefox OFFLINE
jadefox
  • 15 Thanks
  • 49 posts
Posted November 10, 2012 - 12:45 PM
What's a good price for a three-point hitch?
http://www.ebay.com/...d=221146062022
#26 Cat385B OFFLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted November 10, 2012 - 02:09 PM
Under $250 is a good deal.
#27 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted November 10, 2012 - 08:04 PM
Not good but Great! :D
A few things Case,
1)both Case 3 point and sleeve hitch plans can be found on-line.
2)As far as the carb, also check the O-rings on the two needle valves,
I had one Onan that was driving me crazy until I found one was split, causing x-tra air to enter.
3) Many Onan parts can be found at Searspartsdirect.com,link is below,or you need a part # to in-put into part# search.
4) Part and owner's manual per your tractor serial # should be the first thing on your list to get, both can be found
as a rule on-line for free.
5) Good Luck with your tractor, http://www.searspart...Model=B48M&blt=
Edited by John@Reliable, November 10, 2012 - 08:05 PM.
#28 mtoney OFFLINE
mtoney
  • 824 Thanks
  • 685 posts
Posted November 10, 2012 - 08:18 PM
Onans will hunt when running lean. The carb may just need a good soaking in a carb cleaner can, you can get that at the local auto parts store, Gumout among others offers them, then using a spray can of carb cleaner, blast out all the different tubes and orifaces, anywhere gas or air goes. Most likely there is dirt or varnish in the jets causing her to run lean, which will also cause it to run HOT, a big NO NO on an Onan. I have to put a new carb on a 318 JD as we cannot get the jets cleared, new carbs are $252! The intake runner that goes to each cylinder is made of 2 seperate castings and the gasget has a tendency to go bad and leak, the carb cleaner/wd40 test they describe above is the way to test for that. I have rarely seen the block to intake runner gasget go bad, but the runner one I have seen many. Most likely its the carb though. Do not work her hard till you get that problem fixed. Great buy, enjoy her. Mike
#29 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,822 Thanks
  • 2,781 posts
Posted November 10, 2012 - 09:41 PM
Hello! Nice looking black frame 448 you have there! Gary's place (www.gphope.com) is where I get parts for onan motors. He is very reasonable. his phone number is on the web site. Give him a call about your carb issue (yes, he or his wife will answer the phone) and he will help to straighten it out. A very knowledgable person. Knows his onans very well. His shop rebuilt the motor in my old case 446 for me. Did an awesome job.
3-point hitches are expensive. expect to pay at least $600-800 for one. A sleeve hitch will work too. They run in the neighborhood of $200-400 bucks.
#30 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1,227 Thanks
  • 1,083 posts
Posted November 11, 2012 - 10:38 AM
Congrats on the new tractor,looks like you found a good one! Here's a link to the parts list page from the ingersoll site,the 448 can be found under the heading compact tractors manual steering http://eastmanind.com/INGERSOLL/IngersollAttachments/tabid/196/Default.aspx
Also tagged with one or more of these keywords: case 448, ingersoll, onan
