Case 220 Engine Question
kohler k241 k301 cub cadet
10 replies to this topic
#1 RAJ OFFLINE
RAJ
    JMC fan
  • 324 Thanks
  • 323 posts
Posted November 07, 2012 - 09:53 PM
I am looking at buying a Case 220 that is missing the engine. The owner says everything else is there except the engine. Is there anything about Case's Kohler engines that is specific to Case? I have a K301 from a Cub Cadet 125, but I'd like to know what will/won't work before I decide to pick it up. I've never owned one, so can anyone help?
#2 CASENUT OFFLINE
  • 505 Thanks
Posted November 07, 2012 - 11:11 PM
Well there are 2 things that you need to be concerned with. One is input the other output. for example, the kohler has 2 sides to it the 'front' side has a shaft which is used for the PTO, to power implements, decks, snow blowers etc...the other side a hydraulic pump bolts to via a love joy connector. so you will definitely need that. Aside from those 2 basic differences the Case has a fuel pump because the tank is under the seat and i believe the cub has a gravity fed carb, the fuel pumps are 'attainable' so, if you can deal with the clutch, and the lovejoy for the hydraulic pump you're good...
#3 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,089 Thanks
  • 1,284 posts
Posted November 08, 2012 - 01:33 AM
Rajkoski......I'm no expert that's for sure but I'm working on my '71 444 right now and have the hood off so I thought I'd throw a few pics your way in case the 220 and 444 are similar. If someone advises that they aren't similar at all feel free to disregard the pics.
  • RAJ said thank you
#4 jms180 OFFLINE
jms180
  • 1,790 Thanks
  • 1,696 posts
Posted November 08, 2012 - 07:52 AM
While on the subject of Case GTs this one is near me but i think to much he wants $2600.00. I thought you guys might like to look at pic 3E53L53I85S15S05S3cb76530c8c65261129d1.jpg 3n23I93Lf5Q15Fa5S0cb77f6702e906d411471.jpg 3Gc3L73H15S45S35S2cb77292d89269af190b1.jpg 3F33Ib3o05S65S15S2cb790fde50f974611c11.jpg
Edited by jms180, November 08, 2012 - 08:05 AM.
#5 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,311 Thanks
  • 10,287 posts
Posted November 08, 2012 - 08:00 AM
What about the oil pan/motor mounts?
#6 RAJ OFFLINE
RAJ
    JMC fan
  • 324 Thanks
  • 323 posts
Posted November 08, 2012 - 09:01 AM
The owner says the hydraulic pump is there and assumes everything else is too. I heard that there is a "step" on the PTO side of the engine that the pump bolts to on the Case. The 10hp would have had a flat oil pan and my K301 has a dipped pan, which I know can be changed with a different rod. Just wondering if the PTO shafts are different between Case and IH Cub.
As for the 2600.00 tractor, I have seen this much asked for the Big wheeled tractors, but definitely out of my interest level at that price range. If I spend that much for an old GT, it's going to be an Oliver or something rare like that. You could look at it a different way too though. What kind of GT can you buy new for that money? You have to decide if it's worth it to you. Other opinions may not matter.
  • jms180 said thank you
#7 jms180 OFFLINE
jms180
  • 1,790 Thanks
  • 1,696 posts
Posted November 08, 2012 - 09:37 AM
Thanks Rajkowski. It is out of my price range but i sure would like to have it. I agree with you on the Oliver.
Moosetales nice looking Case you have.
Edited by jms180, November 08, 2012 - 09:40 AM.
  • Moosetales said thank you
#8 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted November 08, 2012 - 11:05 AM
2600 looks steep to me even for up here. I'm not sure if this is an issue for the motor swap but some Kohler blocks have the external mounting tabs and some have the threaded holes in the block.
#9 CASENUT OFFLINE
  • 505 Thanks
Posted November 08, 2012 - 11:06 AM
to the op...I'm pretty sure the 220 was gear driven...it is probably just a bit different from the 444 depicted...
#10 mac102004 ONLINE
mac102004
  • 410 Thanks
  • 454 posts
Posted November 08, 2012 - 04:05 PM
It's worth about half then in the market we have up here.
#11 RAJ OFFLINE
RAJ
    JMC fan
  • 324 Thanks
  • 323 posts
Posted November 08, 2012 - 11:15 PM
Thanks for the pics, moosetales. The main question I had was whether the Case's "torque tube" will bolt to the Cub's Kohler. I was told by a local Machinist/Garden Tractor Puller friend that the Case Kohlers had a "step" cast into the block for the love/joy to bolt on to....
I guess I won't know for sure unless I get it home and try. My friend said he's got a Case block that we could switch the internals if need be.
