Lgt 165 Gets New Shoes!
34 replies to this topic
#16 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted November 07, 2012 - 08:53 PM
Those are the kind of tires I am wantin for my 195 if I could ever get my hands on 2 of them,, Looks great Kenny,, Are you talking about filling the inside of them with something for weight?? Plus weights on the outside also??
#17 Cat385B ONLINE
    HAZMAT CAT
  • 14,261 Thanks
  • 10,108 posts
Posted November 07, 2012 - 09:03 PM
10.50's. They measure a bit over 9" wide at the tread.
Wow, that Ford is bigger than it seems. Those tires look smaller mounted on there. Lots of room under that fender pan, I guess.
#18 MH81 OFFLINE
Posted November 07, 2012 - 09:13 PM
Mean looking Ford Kenny. The Ags really make it look like it's ready to go work.
#19 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted November 08, 2012 - 12:18 AM
Kenny, Those AG's look great on the Ford. All that weight will really make her pull good. :thumbs:
Great idea on the 2 valve stems also !!
#20 mjodrey OFFLINE
Posted November 08, 2012 - 05:29 AM
Wow Kenny,those look great.Make the Ford look even more awesome.
#21 KennyP ONLINE
  • 40,126 Thanks
  • 46,764 posts
Posted November 08, 2012 - 05:53 AM
They will each get 7 gallons +/- of WWF inside. With me on it, it should weigh in around 1300-1400 lbs.
There is a lot of space above the tires, but not as much in front of them.
  • Russ said thank you
#22 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted November 08, 2012 - 07:21 AM
Those tires give it a new look!
#23 JDBrian ONLINE
  • 9,643 Thanks
  • 14,158 posts
Posted November 08, 2012 - 08:30 AM
Those look serious on there Kenny. That should give you all the grip you need!
#24 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted November 08, 2012 - 06:51 PM
But what is WWF ??? Thats where I am lost at,,,lol
#25 Cat385B ONLINE
    HAZMAT CAT
  • 14,261 Thanks
  • 10,108 posts
Posted November 08, 2012 - 06:52 PM
Windshield Washer Fluid.
#26 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted November 08, 2012 - 07:10 PM
That Ford looks great!! :good_job:
What do you use the brake rotors for? Extra weight? If so where do you mount them?
Geno
#27 KennyP ONLINE
  • 40,126 Thanks
  • 46,764 posts
Posted November 08, 2012 - 07:23 PM
Yep, WWF is windshield washer fluid. Around 8 lbs. per gallon.
That Ford looks great!! :good_job:What do you use the brake rotors for? Extra weight? If so where do you mount them?Geno
The brake rotors hold my lead weights on the wheels. The thread is here.
#28 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted November 08, 2012 - 08:32 PM
Glad you got the ags mounted up Kenny, they look great.
#29 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted November 08, 2012 - 09:06 PM
Great use of brake rotors! I have 2 and 2 drums also and have been trying to figure out how to make my weights. That gives a lot of insight to it. I also have access to lead from water lines we replace at work. I will have to do some playing around with the idea. Did the extra weight make a big difference in the Ford's performance?
Geno
#30 KennyP ONLINE
  • 40,126 Thanks
  • 46,764 posts
Posted November 09, 2012 - 04:32 AM
Geno, the lead helped quite a bit. Now, with the AG's and loading them, I should see a bunch more improvement. You have to realize the Ford have a limited-slip rear axle, so both tires are pulling. It may be a while before I get to try it out,though.
