Lgt 165 Gets New Shoes!
34 replies to this topic
#1 KennyP ONLINE
  • 41,524 Thanks
  • 47,427 posts
Posted November 07, 2012 - 05:27 PM
I got the AG's on the Ford today. I haven't put the weights back on as I plan to fill these with WWF. I also cheated for filling. The normal valve stems are on the outside under the weights. I drilled and installed new ones just opposite on the inside. Now, when I fill them, I can take the core out of the stems and don't have to worry about 'burping' them. If they are holding air (no bead leaks), I will fill them soon.
  • daytime dave, MH81, Texas Deere and Horse and 3 others have said thanks
#2 daytime dave ONLINE
  • 4,986 Thanks
  • 6,611 posts
Posted November 07, 2012 - 05:38 PM
They look great Kenny. That was a good grab on them.
#3 Arti OFFLINE
Arti
  • 1,388 Thanks
  • 1,002 posts
  • Location: South West Wisconsin . Now in North Central Mo.
Posted November 07, 2012 - 05:46 PM
The ags sure give it an aggressive look. Good idea on putting valve stems on the outside.
#4 KennyP ONLINE
  • 41,524 Thanks
  • 47,427 posts
Posted November 07, 2012 - 05:50 PM
Arti, the stems are normally on the outside. But I have to take the weights off to add air. So the new ones are inside. Shouldn't take long to fill them!
#5 olcowhand ONLINE
  • 43,182 Thanks
  • 32,014 posts
Posted November 07, 2012 - 06:40 PM
She looks good with the new ags Kenny! I like your double valve stem trick! Now to figure how to do that with a tube! :smilewink:
#6 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,700 Thanks
  • 4,655 posts
Posted November 07, 2012 - 06:49 PM
looks good, i like my ags too, don't plan on filling mine, but if i do, i like the doubble valve trick also.
#7 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted November 07, 2012 - 07:21 PM
I'll be honest...I don't remember what you had, but I like those on there now :thumbs: The double valve is a good idea, like you said cause of weights, also can work for better access on duals.
#8 Arti OFFLINE
Arti
  • 1,388 Thanks
  • 1,002 posts
Posted November 07, 2012 - 07:33 PM
Thanks the heads up Kenny.. Fingers in gear and my brain wasn't...
#9 tinbender7 OFFLINE
tinbender7
  • 1,115 Thanks
  • 784 posts
Posted November 07, 2012 - 07:42 PM
I like the ag's on there. looking for a set for my LGT 165, I have a set on my 100. I am not going fill mine as the main thing I use them for is to ride.
#10 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted November 07, 2012 - 07:46 PM
Very cool, ag's look good on just bout everything in my opinion....
#11 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted November 07, 2012 - 07:56 PM
Those look great! I am going to pick up a couple sets of ags soon one for each of my tractors along with some 24-12-12 turfs . But need to widen up a few sets of rims to 10" . ;)
#12 KennyP ONLINE
  • 41,524 Thanks
  • 47,427 posts
Posted November 07, 2012 - 08:06 PM
Not sure if it would help if you had tubes, other than letting the air out from around the tube. I know i will have to have the stem at 12 o'clock to add air, though.
What surprised me was these weigh the same as the turfs I took off. I thought with them being 4-ply, they would weigh more. But they both are 37 lbs (unfilled). I'll add 55 lbs. +/- to that plus 75 lbs. of weights. So I will have 165-170 lbs. per side of weight. Should make those AG's dig in.
P.S. I have another set of brake rotors, too!
#13 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted November 07, 2012 - 08:08 PM
Looks great Kenny
#14 Cat385B OFFLINE
    HAZMAT CAT
  • 14,458 Thanks
  • 10,184 posts
Posted November 07, 2012 - 08:30 PM
Kenny, are those 8.5's?
#15 KennyP ONLINE
  • 41,524 Thanks
  • 47,427 posts
Posted November 07, 2012 - 08:43 PM
10.50's. They measure a bit over 9" wide at the tread.
