What To Soak It In...
12 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted November 06, 2012 - 01:35 PM
What could I soak deck gear boxes in to get rid of grease build up and grime with out messing up the rubber in the seals?
Sent from my HTC One X
#2 Guest_gravely-power_*
  • Guests
Posted November 06, 2012 - 02:53 PM
Mineral spirits/paint thinner.
#3 johndeereelfman OFFLINE
johndeereelfman
  • 5,726 Thanks
  • 2,599 posts
Posted November 06, 2012 - 03:38 PM
Bug & Tar Cleaner, then clean with water and Dawn Dishwashing Liquid. The Bug & Tar cleaner will break down all of the grease and oil, and the dawn will get everything clean without a greasey residue.
#4 UncleWillie OFFLINE
  • 14,966 Thanks
  • 8,504 posts
Posted November 06, 2012 - 04:09 PM
Straight simple green.
#5 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted November 06, 2012 - 04:54 PM
I use the same thing for ALL grease and grim removal and its the most simple thing you can think of and I stumbled on it by accident, it removes all and is super cheap even the "no-name" brand at the dollar store works just as good...ready?? SCRUBBING BUBBLES......yal think I'm kiddin...I'm not. That stuff works like you wouldn't believe and like I said its super cheap.
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 06, 2012 - 05:06 PM
i'LL SECOND THAT!!
#7 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted November 06, 2012 - 05:36 PM
Thanks guys.
#8 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 12,211 Thanks
  • 9,168 posts
Posted November 06, 2012 - 06:29 PM
Try your wife's dish washer!!! :thumbs:
#9 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 06, 2012 - 07:19 PM
Might be better to get one of your own. Wife s uncle built a lot of hot rod engines and had one in his garage.
#10 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted November 06, 2012 - 07:47 PM
Mineral Spirits work great, but I also like Castrol Super Clean.
Matt
#11 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted November 15, 2012 - 08:35 PM
Spray Nine and Hot water !
  • IamSherwood said thank you
#12 KennyP OFFLINE
  • 35,054 Thanks
  • 44,081 posts
Posted November 16, 2012 - 12:11 AM
What is 'spray nine'?
#13 BairleaFarm ONLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted November 17, 2012 - 04:38 PM
The simple green is working so well.
