Does This Spyder Gear Look Familar
6 replies to this topic
#1 speedyx OFFLINE
speedyx
  • 8 Thanks
  • 43 posts
Posted November 06, 2012 - 11:54 AM
This is the eleven tooth spyder gear used in speedex.Wonder what other applications it was used for?
#2 RoosterLew OFFLINE
RoosterLew
  • 82 Thanks
  • 139 posts
Posted November 06, 2012 - 11:55 AM
Do you have any sizes on it? I have a bit of a gear collection I could look at.
  • speedyx said thank you
#3 speedyx OFFLINE
speedyx
  • 8 Thanks
  • 43 posts
Posted November 06, 2012 - 12:19 PM
The gear, Bore .75 Width .95 at pin bore Taper from top to bottom 2.4 to 1.94 11 teeth Tooth length 1.20
#4 speedyx OFFLINE
speedyx
  • 8 Thanks
  • 43 posts
Posted November 08, 2012 - 12:47 PM
evidently not too familar
#5 bolex OFFLINE
bolex
  • 123 Thanks
  • 313 posts
Posted November 08, 2012 - 05:59 PM
i've never degreased mine enough to see the spider gear :D
#6 Gfann OFFLINE
Gfann
  • 194 Thanks
  • 228 posts
Posted December 08, 2012 - 01:28 PM
First thing that I think of is a starter gear for newer tractors except it doesn't have the spiraled groove on the inside of bore. Of course you might not be able to use it for that even if it did have the groove because it would be to hard, those gears are usually made to wear out. I like saving all my gears from old stuff, you never know what can come of them.
Edited by Gfann, December 09, 2012 - 10:02 AM.
#7 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,471 Thanks
  • 5,770 posts
Posted December 11, 2012 - 04:35 PM
First I'd try to cross-reference the tranny maker's products unless they were Speedex exclusive. Usually some other manufacturer's machine from that year used the same part. Just a suggestion..
