Bolens 1050 keeps frying the points
13 replies to this topic
#1 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted August 14, 2010 - 08:14 PM
Got a little 1050 that keeps burning the points after a few minutes.I have looked at everything and can not find the problem.Changed the key switch,regulator,stater generator,coil and so on and can not find a grounded wire anywhere any thoughts.
#2 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted August 14, 2010 - 08:17 PM
Did you try the condenser?
#3 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted August 14, 2010 - 08:29 PM
Tried that to.
#4 olcowhand OFFLINE
  • 44095 Thanks
  • 32301 posts
Posted August 14, 2010 - 08:43 PM
If the condenser is the correct one & good, then you may have a non resisted coil on there (or coil going bad). Got a ballast resistor to add, or a different coil?
#5 Bolens 1000 ONLINE
  • 17303 Thanks
  • 18797 posts
Posted August 14, 2010 - 08:53 PM
:ditto:
#6 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted August 14, 2010 - 09:15 PM
Yea i put in new wisconsin points and a new wisconsin coil.But i will have to check that i grabbed the correct points and condencer off the shelf.This thing just has me baffled.
#7 olcowhand OFFLINE
  • 44095 Thanks
  • 32301 posts
Posted August 14, 2010 - 09:48 PM
Is there a difference in condensers when using magneto or 12V coil?
#8 Bolens 1000 ONLINE
  • 17303 Thanks
  • 18797 posts
Posted August 14, 2010 - 09:55 PM
I wouldnt think so...
Some of mine used to run on magneto's but I converted them to coil's without changing the condensors and have not had any problems...
#9 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted August 14, 2010 - 09:58 PM
:ditto:
None that i am aware of.
#10 ducky OFFLINE
  • 2312 Thanks
  • 4300 posts
Posted August 14, 2010 - 10:07 PM
Some thing is causing a high current at the points or an arc due to a condenser issue.
Coil Low resistance or bad or improper condenser.
#11 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted August 14, 2010 - 10:11 PM
From what I know if your burning up your points there's to much current going though them, like olcowman says put a resistor in the circuit to cut done the current. The condenser acts like a buffer, reduces the arcing when the points open and close, the more current the more arcing, may need different condenser for different current's??? "just my 2cents worth".
#12 ducky OFFLINE
  • 2312 Thanks
  • 4300 posts
Posted August 14, 2010 - 10:39 PM
Just my 2 cents worth.
I coil that requires an external resistor has a primary resistance in the area of .2 - .5 Ohms.
If it is made to operate with out an external resistor you will see a primary resistance of about 1.2 - 1.8 ohms.
When checking a system with and external resistor you should see a voltage drop of 6-8 volt across the coil primary and the remainder of the system voltage drop across the external resistor. For example system voltage with engine running = 13.7 volts. Voltage drop across coil = 8 volts thus the voltage drop across the resistor will be 13.7 - 8 = 5.7 volts
#13 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted August 14, 2010 - 11:03 PM
Thanks for the input guys.After my arm heals from the surjury i had thursday i will get back to looking to see what i missed.
#14 caseguy OFFLINE
  • 1634 Thanks
  • 5600 posts
Posted August 15, 2010 - 02:46 AM
If there is a short inside the secondary, effectively reducing the number of turns, then the secondary voltage would be lower causing the current to be higher. I don't know how likely that is or what kind of resistances you'd be looking for, but if you have several to test you could get an idea what to look for.
