575135 Locking Diff Oil Seal
9 replies to this topic
#1 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted November 04, 2012 - 05:02 AM
Hey guys.I have 575135 DB. I have purchased the axle seals from NAPA already. Does anyone have the part# for the seal that is on the locking differential mechanism? Thanks
#2 Virginia Mike OFFLINE
Virginia Mike
  • 16 Thanks
  • 30 posts
Posted November 17, 2012 - 09:41 AM
Since no one has replied, suggest you measure shaft and bore diameter, the have NAPA look the number up in their cross-over books.
If you have a clerk that is interested in doing that, If not, try a commmercial bearing supply.
  • VSTROM803 said thank you
#3 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted November 17, 2012 - 08:49 PM
Would you believe that is exactly what I did? I took measurements, went to NAPA, got an uninterested clerk then went to a commercial bearing supply dealer. That was yesterday. I put it back together today. I also replaced the springs for the locking differential.
.If anyone needs part #'s I will gladly post them.
#4 Virginia Mike OFFLINE
Virginia Mike
  • 16 Thanks
  • 30 posts
Posted November 18, 2012 - 08:40 AM
It has been said; " You know you are in trouble when the parts person is younger than the machine you are working on."
Yes, please post the numbers!
#5 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted November 18, 2012 - 08:53 AM
He didn't sell you the wrong part, you're just working on the wrong thing.
#6 Virginia Mike OFFLINE
Virginia Mike
  • 16 Thanks
  • 30 posts
Posted November 19, 2012 - 07:29 AM
The dirtest trick in the parts mans book, is to sell you the wrong part so he has time to get the right one before you return to exchane it.
#7 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted November 19, 2012 - 08:02 PM
The NAPA seal #'s are
18581 axle seal
11223 axle seal
7513 clutch shaft seal
The locking diff seal is a TCM #03072SM. The equivalent in National would be 330385.
I matched up the springs for the differential at a hardware store. They measure as follows:
1 5/16" long x 1/4" diam. with 10 coils.
  • Alc and Virginia Mike have said thanks
#8 robbor OFFLINE
robbor
  • 3 Thanks
  • 7 posts
Posted February 17, 2013 - 01:30 AM
Will these seal part numberes work on the earlier 5751?
#9 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted February 17, 2013 - 05:08 AM
The axle seals will not the differential tractors have a big axle and a small axle. The clutch shaft seals might be the same.
#10 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted February 17, 2013 - 05:26 AM
Will these seal part numbers work on the earlier 5751?
Here are the numbers for the non-differential tractors:
CR11223 - axle
CR7513 - Clutch
If your axles are pitted you can probably double up the seals to help stop the leaking.
