"new" Snapper Rear Engine Rider From 60's Info.....
19 replies to this topic
#16 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,989 Thanks
  • 2,480 posts
Posted November 07, 2012 - 06:49 AM
The model and serial tag is missing, and it has a replacement 8HP Briggs on it. I am trying to figure out what model it is so I can get the correct parts manual. It has hard rubber front tires, and the early metal rounded gas tank. Blade is 28" long. Also has the rectangular handle.
Your Snapper Comet riding mower is a 30" cut model. ....If it has a 28" blade, it has the wrong blade on it.
Snappers were made in 25", 26" 28", 30", 41" and 42" cuttting widths over the years. .....The 25" mower was the only model to use semi-pneumatic ("hard rubber") tires. ....All the others had 4.10-3.50 x 4" pneumatic front tires.
The 25", 26" and early 30" models used 4.80/4.00-8 rear tires. ....Later-model 30" mowers and the others used 16-6.50 x 8" rear tires.
25" and 28" mowers were Hi-Vac models. ......The 41" and 42" mowers had multiple blades while the 25", 26", 28" and 30" used a single blade. .....For best bagging results, the Hi-Vac models were better than the others. ....However, the non-Hi-Vac models do a better job of spreading the clippings if bagging is not a priority. .....There were air-lift extensions which could be bolted to the single blades to improve the bagging performance.
I would guess that your mower is a Snapper Comet model 307X or 308X, from the 1970's. .....Both of these models had the wide rear tires and loop-style steering handle. ....The 307X had a 7hp B&S engine, while the 308X had an 8 hp B&S engine. (The first four numbers of the B&S Code number will indicate date of manufacture. ...It's possible that your engine is the original engine.) ......B&S model 170702 was 7hp, while B&S model 190702 was the 8hp.
(By the way, your steering handle is mounted incorrectly. .....Remove the bolts and turn it 180*. .....This will prevent the steering handle from hitting your knees when making turns.) ....The seat pan could be mounted in different holes to adjust the seating position.
Snapper riders used mostly B&S engines, but Tecumseh engines were also used on some models. ....The 41" mower had a Wisconsin engine.
#17 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted November 07, 2012 - 08:24 PM
There was also a 33" HiVac deck as well.
Also the 25" RER I have has the same front tires and wheels as my 30" does.
Edited by Amigatec, November 07, 2012 - 08:27 PM.
  • Bruce Dorsi said thank you
#18 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted November 07, 2012 - 09:58 PM
Ok, I have the briggs shroud in front of me, numbers are as follows: model# 190702 Type#1175-01 Code#82031812. Now I guess that just the shroud could have been replaced somewhere along the line. Does a 30" blade really measure 30"?
#19 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 3,989 Thanks
  • 2,480 posts
Posted November 08, 2012 - 09:21 AM
You're right !! .....I completely forgot about the 33" models.
#20 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted November 10, 2012 - 05:13 PM
Ok, I have a good update! This snapper runs now and mows too. I does still have issues to deal with, but at least it runs and mows. Thanks again for all theinformation and i will keep up on the updates. BTW, this is the best forum that I go on. Wish there was one that dealt with push-mowers, as I have a few old ones as well. thanks again!!!
