New To Me Generator
10 replies to this topic
#1 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted November 02, 2012 - 05:28 PM
A few days ago I was talking with neighbor Herby. We were talking of the power outages with Sandy, and he said he has a generator that has been sitting for twenty years or so. He told me I could have it if I wanted it; I went over and got it from him today.
The engine is seized, and it would need a lot of attention to get it running. Even though it is stuck, It is still good for parts, or whatever else I want to use it for!
I took off the shut off button. It is a cover that goes over the spark plug, push the button and it grounds out the plug. My other generator has a wire that I put on last minute before the storm for a shut off switch. I wanted to put it onto that engine, but the head cover does not clear it. Oh well!
#2 KennyP ONLINE
  • 40,978 Thanks
  • 47,148 posts
Posted November 02, 2012 - 06:12 PM
Maybe you can adapt the generator to a tractor! Then you would have mobile power.
#3 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted November 02, 2012 - 06:15 PM
I thought about that, but last week boyscout862 suggested that I could just use a power inverter! I don't think it is a bad idea, the power kings use full size car batteries and it would definitely be more compact and easier!
#4 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted November 02, 2012 - 06:18 PM
Is it the motor or the generator that is locked?
#5 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted November 02, 2012 - 06:21 PM
The engine, when I took the plug out to take off the shut off button it looked BAD in there!
#6 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted November 02, 2012 - 06:27 PM
I was wondering the same, as rust could have formed between the armature & field coils, but if it looks that bad down the spark plug hole.......
#7 KennyP ONLINE
  • 40,978 Thanks
  • 47,148 posts
Posted November 02, 2012 - 06:28 PM
But an inverter doesn't put out as many amps as that generator does.
#8 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted November 02, 2012 - 06:33 PM
It's possible the generator doesn't have a bearing the crankshaft end, the main bearing in the motor acts as the generator bearing.
#9 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted November 02, 2012 - 06:34 PM
You may also be able to find another 6hp motor to use for parts. The crank in this one will be tapered.
#10 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted November 02, 2012 - 06:38 PM
I've never seen a motor mounted generator that didn't use the crank's main to support that end of the gen.
#11 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted November 02, 2012 - 07:37 PM
I just recently seen a couple generators on CL in my area that mount to the front of a GT. Looked like a good idea...
