Weight Bar/ Hitch For The '71
18 replies to this topic
#1 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 02, 2012 - 05:03 PM
I am making a weight bar, that is going to have a stationary hitch welded to it. I started some fabrication the other day.
This is what the rear looked like before I got started.
I then got rid of all of the hitch components, except for the blocks that slide into the frame.
In order to get one of the blocks off, I had to cut the hitch. I am not worried about this part, I already bent and poorly fixed it once. I don't plan to go back to the hitch anyway, I will put a 3 point on before I put a plane hitch on. The othe side is held on with a cotter-pin.
I decided to grind off a little material, so they would slide in the frame better.
I am going to weld a piece of angle across the two blocks. I will put a bar going vertical that the weights will go onto. The bar will extend downward past the bottom of the angle. That will add some strength to the C channel I will use to make the hitch.
I ground a chamfer into the blocks, this way I will be able to get a little bit better penetration on the big blocks and it will be stronger when I weld it.
#2 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted November 02, 2012 - 06:35 PM
As always, looking good Ryan. :thumbs:
  • Ryan313 said thank you
#3 farmer OFFLINE
farmer
  • 9 Thanks
  • 94 posts
Posted November 02, 2012 - 06:53 PM
Ryan which tractor are you doing this on?
#4 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 02, 2012 - 06:58 PM
My 1971 power king 1614.
#5 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted November 02, 2012 - 07:35 PM
Looks really good. Deff sounds like you know what your doing.....
#6 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 06, 2012 - 05:07 PM
I welded everything I have together today. It did not come out to bad. I am not happy with a few of the welds, but it should hold fine.
Since I torched the hole for the bar to go through, I had to weld on both sides of the angle to properly fill in the hole. I need to get a new grinding wheel so I can grind down that weld, and the ones on the sides.
During final welding, something moved! The two blocks that slide into the frame where to close together. I had to get creative and spread them apart about an 1/8 inch. I ended up using an engine hoist.
Perfect! Ok, maybe not perfect... but good enough!
I have several different 25 pound weights that are different diameters. The one below has the largest diameter and I still have a few inches of clearance.
Have once again changed mt hitch design! I think, I will have to look around in the welding and machine shops at school to see what material I can use from there. The reason is that no matter how I decide to make the hitch, I will not have strong enough material to do it with.
#7 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 14, 2012 - 03:12 PM
On Friday, I brought the weight bar to my welding class to make the hitch on it.
Yesterday, I cut out cardboard and taped it all together on the weight bar to see how it would be done and what material would be used.
Today, I cut all of the steel pieces out.
I should be able to at least get everything prepped for welding tomorrow.
#8 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted November 14, 2012 - 03:38 PM
Looking great Ryan, can't wait to see what you ended up building.
#9 KennyP ONLINE
  • 38,221 Thanks
  • 45,860 posts
Posted November 15, 2012 - 08:57 AM
Looks good, Ryan. Welds don't have to be pretty all the time. But I can understand where you are coming from.
#10 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted November 15, 2012 - 10:34 AM
Ryan, nice job on the weight bar. Simple and effective. Also nice job on getting it to fit back in the frame. Don't forget the expantion and contration cycle that the steel goes through when you weld it. Look at the picture I attached. Likely what happened is the high amount of weld (red circle) on the inside of the angle shrunk when it cooled and bent the angle (red line)to cause the tips of the blocks to be too narrow (black arrows) to fit back into the frame rails.
#11 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 15, 2012 - 03:55 PM
That is a very good explanation! And I bet that is exactly what happened!
#12 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 15, 2012 - 08:32 PM
Today, I got all of my torch cuts cleaned. I however did not have time to grind in a few bevels that I need. I needed to cut two notches 1 3/4" deep and 1/4" wide where two of the plates will go around the angle connecting the two hitch blocks. I did not know what the best way to cut them was so I asked the welding teacher, he said to use the plasma cutter. (More info Here) They worked just fine! If I had known I could use the plasma, I would have cut out the plates with it as well! That way, my cuts would have been cleaner!
#13 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted December 21, 2012 - 08:41 PM
I had not been updating this, and it has taken me much longer to built this then I had thought it would. After Ihad all of my pieces cut, I tacked them together and all of my cuts where off. So, I remade some pieces, this time I used the plasma cutter and it went much faster; not to mention how much cleaner the cuts where. The part that really set me back was thanksgiving break.
Anyway, I finished it last week, painted it earlier this week and today I brought it home.
I was worried that with the heat from welding the hitch to the weight bar (I made them separately) would warp it, like it did last time. But, it did not and it went into the frame rails with only a few taps from a rubber mallet.
It holds 8 of my 25 pound weights, which is 200 pounds. This will make a huge difference in my traction! The only problem, is that the weights partially block my rear light.
The holes in the sides where the old hitch would pivot were left alone. I will use these to put a clevis into. They are a few inches above the axles, so I will have to be careful. Since it is also off center, I may have problems with the chain hitting the tire in sharp turns. I will just have to see how it works out.
The hitch ball is two inches farther back then the old hitch point, so my trailer tracking is going to be slightly better.
The part that the ball goes through is 1/2 inch steel, everything else I made in welding class is out of 1/4 inch. I am not at all worried about the hitch bending. The way I see it, it is way overbuilt... just like the rest of the tractor! :D
#14 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted December 21, 2012 - 08:55 PM
Excellent work!
#15 mjodrey OFFLINE
Posted December 22, 2012 - 06:35 AM
That looks great,Ryan.Nice work. :thumbs:
