Help With A Starter Generator
9 replies to this topic
#1 jessylee OFFLINE
jessylee
  • 4 Thanks
  • 20 posts
Posted November 02, 2012 - 12:34 PM
ok i have a starter generator on om 73 cub and it had stopped charging the battery i had R/R the brushes and it still wont charge its not the wireing bc i had installed it on my cub 108 and it would still not charge the battery i don't know whether or not the field coil is bad in the generator and how would u test to see if the field coil is bad would i use contiguity and or resistance if some one would help pleases
#2 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted November 02, 2012 - 12:43 PM
The 73 had a voltage regulator behind the front grill from what i remember. contacts on that could be dirty or welded shut causing it not to charge
#3 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted November 02, 2012 - 12:51 PM
Search articles for "testing a starter generator" and look for an article by me. That should help you determine fault in the system.
#4 drbish OFFLINE
drbish
    Collecter
  • 1,576 Thanks
  • 1,374 posts
Posted November 02, 2012 - 01:01 PM
Here is a repair manual to download
http://gardentractor...arging-systems/
#5 olcowhand ONLINE
  • 43,131 Thanks
  • 32,004 posts
Posted November 02, 2012 - 02:51 PM
http://gardentractor...r-generator-r78
  • wvbuzzmaster said thank you
#6 wvbuzzmaster ONLINE
  • 4,717 Thanks
Posted November 02, 2012 - 03:55 PM
Thanks for grabbing the link Daniel, I was on my Iphone when I posted so couldn't grab the link myself.
#7 glgrumpy OFFLINE
  • 8,848 Thanks
  • 8,035 posts
Posted November 02, 2012 - 04:15 PM
Hey Thanks! "New". I have MTD 990 with one and briggs and that will be helpful when rewiring! I just printed the Start/Gen parts, about five pages and am good. LOVE those pdf set-ups for printing just what you want and etc.
#8 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 619 posts
Posted November 02, 2012 - 07:18 PM
Isn't there a step to polarize the generator or regulator?
#9 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted November 02, 2012 - 07:38 PM
yes but i find it un necessary. If it is working you can unhook the battery and rehook it and still works fine.
#10 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted November 02, 2012 - 09:21 PM
If it's a generator, yes. If it's a starter-generator, no. A starter-generator is self-polarizing when you engage the starter.
  • wvbuzzmaster and motobreeder have said thanks
