Impulse Fuel Pump?
18 replies to this topic
#16 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted November 11, 2012 - 10:26 AM
I got the pump rebuilt and the .pdf completed. The upload can be found here. I put it in the Manuals/Engines/Misc. section as this pump was used on many applications over the years.
If anyone sees an error, please let me know so I can correct it.
  • ducky, MH81 and Analdduh have said thanks
#17 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted November 11, 2012 - 12:23 PM
Thanks for your time to make this Kenny.
#18 RT420 OFFLINE
RT420
  • 2 Thanks
  • 1 posts
Posted February 03, 2015 - 10:42 PM
Hi,
I signed up for the site so I could download this PDF. you made for the "Walbro 3028 Impulse fuel pump"
Everything is correct except for right at the top you have the order of the lines mixed up. The top left line is for the fuel line that leads to the carb and the bottom left line is for the impulse line from the crankcase. You just had that order backwards. I saw your post and hooked them up the way you discribed and it filled the crankcase with fuel from the tank. Thank god I realized before a catastrophic failure. Just thought I would let you know so you could change the PDF. so it doesn't happen to anyone else. Thanks for posting the PDF all the same. It helped me get my tractor running. All the Best...
  • KennyP and TAHOE have said thanks
#19 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted February 04, 2015 - 06:08 AM
I'll have to fix that! Thanks for letting me know!
EDIT: Fixed the wording and reloaded the file!
  • TAHOE said thank you
