Impulse Fuel Pump?
18 replies to this topic
#1 KennyP ONLINE
  • 37,377 Thanks
  • 45,442 posts
Posted November 02, 2012 - 09:24 AM
The GT18 has this type of fuel pump. Is there anywhere to find a kit for it? I may not be looking in the right place.
It is a Walbro pump, Model 3028, with 0595 stamped below that.
  • Analdduh said thank you
#2 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted November 02, 2012 - 10:14 AM
You could check on searspartsdirect.com. Look under the model number for the tractor.
I have a few from Craftsman II's but have never had to rebuild them. Rebuild kit is probably in the $15-20 range.
One option would be this: http://www.ecrater.c...fuel-pump?gps=1
Pretty cheap, no rebuild time but you may need to drill a hole or two to mount it.
#3 UncleWillie OFFLINE
  • 15,514 Thanks
  • 8,701 posts
Posted November 02, 2012 - 10:18 AM
http://www.jackssmal...Parts-4-Cycle/s
http://www.ereplacem...716_142779.html
  • Alc, KennyP and Analdduh have said thanks
#4 skyrydr2 OFFLINE
  • 3,869 Thanks
  • 3,401 posts
Posted November 02, 2012 - 11:06 AM
Kenny, did you take it apart yet ? Those can sometimes be revived with a good thou rough soaking in mmm or WD 40. All it needs is the diaphram and pedals softened up usually.
  • dstaggs and KennyP have said thanks
#5 KennyP OFFLINE
  • 37,377 Thanks
  • 45,442 posts
Posted November 02, 2012 - 12:31 PM
Sears parts doesn't show a kit for these. Only the pumps that are on the carb, which this is not. I'll do some research l;ater on these other leads. Thanks guys!
#6 glgrumpy ONLINE
  • 8,549 Thanks
  • 7,877 posts
Posted November 02, 2012 - 04:00 PM
Good luck! I never found parts for carb mounted kind, looks same. Did find a Kit for $39, but wasn't too good and I passed on it. Sears , no help anymore. Was told no one had parts/kits now. I have NOT seen those leads presented tho and probly worth a look. I ended up putting on a generic one from my local shop and just had to mount it somewhere else, run lines. It was all plastic of course and about $20. Common as these are/were, not sure why you can't find kits anymore??
#7 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted November 02, 2012 - 04:34 PM
I checked one I had, Mod #3028. Kit is no longer available.
This is the wally recommended replacement, kind pricey. http://www.milfordpo...t-p/520-159.htm
The problem with most of the replacement is, yours is probably firewall mounted with 2 hoses on the front and 1 on the back and the replacements have the hoses coming out the sides.
Edited by rat88, November 02, 2012 - 04:37 PM.
#8 DH1 ONLINE
DH1
    Electric Tractors
  • 5,231 Thanks
  • 5,546 posts
Posted November 02, 2012 - 05:19 PM
I think this is what you need.
http://www.ebay.ca/i...=item3ef199395f
#9 KennyP OFFLINE
  • 37,377 Thanks
  • 45,442 posts
Posted November 02, 2012 - 05:43 PM
That looks like what I need, Doug. I just bought 2 of them. Thank you!
#10 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,231 Thanks
  • 5,546 posts
Posted November 02, 2012 - 05:46 PM
Same fuel pump used on my Tecumseh 16hp, Over Head valve OH160, the motor I got from a Sears tractor.
#11 KennyP ONLINE
  • 37,377 Thanks
  • 45,442 posts
Posted November 02, 2012 - 06:07 PM
The gaskets have the offset holes correct. I didn't want to take one apart if I couldn't find gaskets for it. Now it's waiting till they arrive! Thank You!
#12 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted November 02, 2012 - 08:21 PM
this thread should be a sticky. I will need a kit 2 or 3 years from now and wont be able to find the number I wrote down.( if they still sell them 2 or 3 years from now)
EDIT: i checked other prices.... Holy Hell ... $40, that is one hell of a deal. New pumps are half the price, they may not fit, but I can bend some hoses for $20
TECUMSEH 33010 WALBRO FUEL PUMP REPAIR KIT 300-691
Item condition: New Quantity:
More than 10 available / 290 sold US $8.99
Approximately C $8.97
Buy It NowBuy It Now
Edited by rat88, November 02, 2012 - 08:32 PM.
#13 KennyP OFFLINE
  • 37,377 Thanks
  • 45,442 posts
Posted November 03, 2012 - 05:18 AM
Once the parts arrive, we'll do something to keep the info secure, rat88! Maybe I can do a .pdf and show pics of the rebuild. Include the parts #'s and info. I think putting in the Manuals/Engines section? Any other ideas?
#14 KennyP ONLINE
  • 37,377 Thanks
  • 45,442 posts
Posted November 05, 2012 - 06:28 PM
I got the rebuild kits today. But it may be near the weekend before I can do much with them.
#15 KennyP OFFLINE
  • 37,377 Thanks
  • 45,442 posts
Posted November 09, 2012 - 08:36 AM
Chances of rain this weekend, so I may be able to get to the pump and do a write up for this. Stay tuned!
