Electric massey garden tractor
270 replies to this topic
#211 KennyP ONLINE
  • 40,954 Thanks
  • 47,136 posts
Posted December 15, 2012 - 06:46 PM
Great looking group you have there!
#212 IamSherwood OFFLINE
  • 8,395 Thanks
Posted December 15, 2012 - 07:21 PM
Lucky you, to have snow to play with.
I bet it's a neat feeling, to walk up to ET, flick the switch, and gooooooo.
#213 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,437 Thanks
  • 5,619 posts
Posted December 16, 2012 - 04:51 PM
No pictures today, it rained on and off all day long have to wait for a better day.
#214 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,437 Thanks
  • 5,619 posts
Posted December 27, 2012 - 08:29 PM
ET2 is back on winter duty plowing the driveway, we got about 3" to 4" of snow. Put the 2 link chains on tonight and use it clearing the driveway.
This yr it has an extra 50lbs of rear wheel weights, 25 per side and the V61 front tires work great.
Edited by DH1, December 27, 2012 - 08:30 PM.
#215 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted December 27, 2012 - 08:34 PM
Glad to hear the ET2 is earning its keep year after year.
  • DH1 said thank you
#216 IamSherwood OFFLINE
  • 8,395 Thanks
Posted December 27, 2012 - 08:35 PM
What, no pictures Doug?
Well, at least you got some snow down there. Just real cold NE wind up here.
#217 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,437 Thanks
  • 5,619 posts
Posted December 27, 2012 - 08:37 PM
Pictures are coming, need daylight.
#218 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted December 27, 2012 - 09:04 PM
Another neat thing about using battery power is that the operator is more aware of the surroundings . People , other noises etc are more able to get his / her attention . If that wasn't in original sales brochures , it should have been :D
#219 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,437 Thanks
  • 5,619 posts
Posted December 30, 2012 - 03:42 PM
Used ET2 today to plow the driveway, for the 2nd time this season. I tried a different blade this time (red) and it does about the same job the other one (yellow) did, no real difference.
This yr I have the gauges on it and I can see what the motor is drawing or how hard it is working.
Discovered that it takes a lot of amps to push snow with the plow.
3rd gear 75amps +, goes up to 125amps.
4th gear 100amps + goes off the scale, more than 150amps
I had being plowing in 4th all the time, tractor goes a little faster but I can now see that if I use 3rd gear it's easier on the motor and it will have more run time. I think I'll be using  3rd gear more often.
In the cold the motor doesn't heat up as much or as quickly as it does in the summer time.
I also learned today that pushing heavy snow is about the same load or amp draw as pulling a 10" plow through the garden.
  • wvbuzzmaster and sacsr have said thanks
#220 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted December 30, 2012 - 04:34 PM
Hey Doug, that is awesome. I like that you now have gauges. What is the style of amp gauge? Is it internal shunt or external shunt, and did you notice any performance hindrance after adding the ammeter?
#221 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,437 Thanks
  • 5,619 posts
Posted December 30, 2012 - 04:57 PM
It's external shunt, mounted in series off the battery, all the power for the tractor goes though it and you only lose 50mv or .05volts.
Not going to notice any power loss.
  • wvbuzzmaster said thank you
#222 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted December 30, 2012 - 05:08 PM
Doug, is the ammeter before or after the controller? Or are you between controller and motor just to see the motor's amps?
#223 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,437 Thanks
  • 5,619 posts
Posted December 30, 2012 - 05:10 PM
Amp meter shunt is right off the battery.
#224 HowardsMF155 ONLINE
  • 2,969 Thanks
  • 3,019 posts
Posted December 30, 2012 - 05:22 PM
I continue to be impressed by this project and your knowledge.  Excellent work!
#225 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,437 Thanks
  • 5,619 posts
Posted December 30, 2012 - 05:25 PM
Heck most of what I know I learned by doing this project.
