V4-6 Restore
371 replies to this topic
#121 Bolens 1000 ONLINE
  • 14,986 Thanks
  • 18,140 posts
Posted December 09, 2012 - 07:14 PM
Looks like your making good progress, looking forward to seeing more :thumbs:
#122 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted December 09, 2012 - 07:56 PM
Coming along 1 step at a time.
Question you have almost the same blast cabinet I have.
What kind of light do you have in it, one that's made for it or a homemade one?
Mine has no light and needs one, just trying to find out what the best way to go is.
I am on my 3rd light. The OE light was a fluorescent, 2nd one the same. I just put in a plain plastic barn light base with a std 100 watt bulb. After screwing the bulb in, I put a piece of duct tape where the bulb meets the base to keep abrasives out. This light seems to work the best.
Good progress, Daniel! We'll be seeing color before too long if the weather holds.
I have good heat in my shop, so cold won't stop my painting. I actually get better results in cold weather because all the bugs & flies are long gone.
Great Daniel, you're moving right along.
Yep, you've got cold air coming your way. A present from us up here.
I was hoping to see pics of you as Santa.
I forgot to take my camera, but Fred (meangreen) will be getting me jpg's . He'll maybe post them here himself.
  • DH1 and KennyP have said thanks
#123 KennyP ONLINE
  • 38,284 Thanks
  • 45,886 posts
Posted December 10, 2012 - 06:07 AM
Glad you have heat. I do too, if the sun shines. LOL
#124 mjodrey OFFLINE
Posted December 10, 2012 - 06:26 AM
Looking good there,Daniel.
#125 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted December 11, 2012 - 05:48 PM
Spent an hour or so in the shop for some mental therapy. Did the soul some good, and got my brake pedal, and some other control parts blasted & under primer. Hoping early next week to shoot paint. Not likely to happen this week after all.
#126 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted December 11, 2012 - 05:56 PM
Glad you were able to get some shop therapy in! That and this site are the best combination. Glad to here you also made progress. :thumbs:
#127 KennyP ONLINE
  • 38,284 Thanks
  • 45,886 posts
Posted December 11, 2012 - 06:01 PM
That's great to hear, Daniel. You need a bit of time to get yourself in order too. I know it sure helped me out last year to have something to work on. Let's you get lost in thought, yet be productive.
#128 IamSherwood OFFLINE
  • 8,391 Thanks
Posted December 11, 2012 - 08:12 PM
That's good Dan. Good move, to take your mind off things.
That said, where are the pictures today?
#129 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted December 11, 2012 - 09:21 PM
Got hungry, so went in the house & ate a BIG supper. Too lazy afterward to go back out with a camera. Not much to see but some smaller parts dangkling in front of my shop heater curing. I'll get a pic or 2 tomorrow. :thumbs:
#130 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted December 12, 2012 - 05:24 PM
Today I only got to split the transaxle. I need to check both axle seals, but out of acetylene, and I will have to heat the right hub to get it off so I can remove the axle tube to get at the seal. The left hub came right off, but the outside flange was already busted up. I have a replacement used hub off a Wheel Horse coming in the mail as a replacement.
The input shaft roller bearing was worn sloppy, but I had another transaxle with a good bearing. Need to go pick up a new input shaft seal. It was totally shot from grass that wrapped around the shaft & ate all the rubber off the seal.
The reverse idler's gear teeth were worn way back in this one, so I'm using the one out of a JD 110 transaxle.
Here's more parts that I got under primer yesterday.
#131 HDWildBill OFFLINE
  • 8,975 Thanks
Posted December 12, 2012 - 05:38 PM
You are just clipping along. You'll be putting it together before you know it.
#132 KennyP ONLINE
  • 38,284 Thanks
  • 45,886 posts
Posted December 12, 2012 - 05:40 PM
I think he wants a ride on it! GO, Daniel, GO!
  • HDWildBill said thank you
#133 HDWildBill OFFLINE
  • 8,975 Thanks
Posted December 12, 2012 - 06:27 PM
I think you are right. :smilewink:
#134 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted December 12, 2012 - 06:42 PM
I've driven it already, but she was butt ugly then! :D I just try to get as much done when I can, as I never know where my time will have to go later. I need to get my free stalls repaired, but haven't made myself start that yet. GT's keep luring me back to my shop! :smilewink:
#135 KennyP ONLINE
  • 38,284 Thanks
  • 45,886 posts
Posted December 12, 2012 - 06:56 PM
Daniel, I'm just happy to see you making progress on it. You've had a full plate lately, good to see you able to work on a tractor!
