V4-6 Restore
371 replies to this topic
#76 olcowhand ONLINE
  • 43,145 Thanks
  • 32,005 posts
Posted November 25, 2012 - 04:39 PM
Body filler applied. Josh is taking tomorrow off, so block sanding may have to wait till Tuesday.
#77 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,371 posts
Posted November 25, 2012 - 05:59 PM
Did you paint with primer then the body putty?? Looking good!
#78 olcowhand ONLINE
  • 43,145 Thanks
  • 32,005 posts
Posted November 25, 2012 - 06:01 PM
I always try to fill over bare metal. Wanted to try sanding, but not cured enough yet. Guess it'll have to wait till Tuesday.
  • sacsr said thank you
#79 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,371 posts
Posted November 25, 2012 - 06:08 PM
So I have been doing it backwards....I have been lightly priming then using putty or body filler......I was worried about surface rust....guess after all the sanding on the body filler I would not need to worry about the surface rust! Thanks!
#80 HDWildBill OFFLINE
  • 8,985 Thanks
Posted November 25, 2012 - 06:21 PM
Looking good Daniel. This is like watching Overhauling but on a smaller scale. :smilewink:
#81 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted November 25, 2012 - 06:36 PM
Great restoration progress so far Daniel, and looks like you have everything under control as you work through it.
#82 olcowhand ONLINE
  • 43,145 Thanks
  • 32,005 posts
Posted November 25, 2012 - 06:53 PM
Scott, it is best to fill directly onto clean bare metal, but it will be ok over primer. That's why I did the electrolysis to get the bulk of the crud off, then waited till I could sandblast the frame and body fill on the same day, before flash rust could come into play. If exposed metal flashes some now, it won't matter, as I will be sanding all down again, then immediately spraying primer over it all. Once I get it under primer & cured well, I'll wrap the frame in an old bed sheet & put away until I get more parts ready for paint.
#83 olcowhand ONLINE
  • 43,145 Thanks
  • 32,005 posts
MUCH smaller, and extremely SLOWER!
#84 KennyP ONLINE
  • 41,461 Thanks
  • 47,391 posts
Posted November 25, 2012 - 07:13 PM
That's going to be one nice frame, Daniel. Sorry about the play time interruption.
#85 IamSherwood OFFLINE
  • 8,395 Thanks
Posted November 25, 2012 - 08:29 PM
Looking good Daniel. Good to see you getting lots done here.
Have you found yourself a starter?
#86 olcowhand ONLINE
  • 43,145 Thanks
  • 32,005 posts
Posted November 25, 2012 - 08:38 PM
There are starters available, but will have to wait till I can sell some stuff to pay for it. Kinda overextended at the moment, plus Christmas coming.
#87 IamSherwood OFFLINE
  • 8,395 Thanks
Posted November 25, 2012 - 09:03 PM
I bet someone in the family, would be happy to have on of those starters, that they could lend you. :D
#88 Fabman OFFLINE
Fabman
  • 257 Thanks
  • 374 posts
Posted November 25, 2012 - 09:26 PM
Always enjoy reading your posts, Daniel. Will be watching for more of your progress.
#89 olcowhand ONLINE
  • 43,145 Thanks
  • 32,005 posts
Posted November 26, 2012 - 07:02 PM
As busy as my day was, I stole a little time before lunch to get the frame under primer. To speed the sanding, I cheated & used my belt sander to do the flat sides. Man was that the trick....finished in a couple minutes each side. Then I finished the sides with my orbital sander, did the tops of the sides by hand, then shot the primer.
#90 KennyP ONLINE
  • 41,461 Thanks
  • 47,391 posts
Posted November 26, 2012 - 07:12 PM
Looks good, Daniel. Glad you got a little time to spend on it.
