V4-6 Restore
371 replies to this topic
#346 IamSherwood OFFLINE
  • 8,391 Thanks
Posted June 27, 2014 - 05:52 AM
Thanks Brian, but I have the trim, and in good shape, but the plain steel mount insert is shot.  So rusty it's expanded tight into the stainless.  I have it in the E-tank so I can remove the mount steel without damaging the stainless.   I have some stainless steel 10/24 thread carriage bolts & stainless nylock nuts coming.  All I have to do is remove the OE steel mount strips, then grind down the rounded carriage head flat, then grind flats opposite on the head edge down to .438" or so, then they will slide into the stainless trim to fasten it to the hood.  The carriage heads measure .454", so I can make a decent flat edge on both sides to grip the stainless trim.
I think I get what you're talking about. Pics would be good, when you do it.
  • olcowhand said thank you
#347 KennyP OFFLINE
  • 38,299 Thanks
  • 45,895 posts
Posted June 27, 2014 - 06:36 AM
Sounds like a good fix, Daniel!
#348 olcowhand ONLINE
  • 41,131 Thanks
  • 31,413 posts
Posted June 27, 2014 - 07:19 AM
Got the stainless hardware, just no time to do anything.
  • IamSherwood said thank you
#349 KennyP OFFLINE
  • 38,299 Thanks
  • 45,895 posts
Posted June 27, 2014 - 07:30 AM
I know that scenario! With the job we're on, I have to cram the weekends trying to keep mowers going!
#350 olcowhand ONLINE
  • 41,131 Thanks
  • 31,413 posts
Posted June 27, 2014 - 11:02 AM
Being I'm on lunch break & waiting for the food, I went down & ground a couple bolts.  I did NOT haveto grind flats on the bolts edges, as it fits fine as-is.  If the nylock nuts spin the bolts, I'll just hold the bolt threads with needle nose pliers to get the nuts ran down.
  I think it will work pretty good, but it takes 9 to each side, so it takes a while.
  • IamSherwood, KennyP and sacsr have said thanks
#351 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted June 27, 2014 - 03:09 PM
Daniel I am looking a buying some stainless steel bolts from your eBay guy. What bolts and nuts do these tractors primarily need? Any chance you gave a list you are willing to share? Yes I am lazy, but I am more concerned I may measure the bolts wrong and my order will be wrong.
#352 olcowhand ONLINE
  • 41,131 Thanks
  • 31,413 posts
Posted June 27, 2014 - 03:36 PM
I will compile a list asap.  Most, but not all come in packs of 25 or more, but very good prices.  I bought a pack of 10 bolts for less than the price of 4 SS bolts of same size/quality from Lowes, and that included shipping from my Ebay guy.  I'll get something together soon.
#353 olcowhand ONLINE
  • 41,131 Thanks
  • 31,413 posts
Posted June 27, 2014 - 06:24 PM
So you can browse, here is the ebay business I get my stainless hardware from.  He is a huge seller!  The link below is ONLY to his stainless steel items, which he has over 19,000 SS items listed right now!
http://www.ebay.com/...inless&_sacat=0
  • Texas Deere and Horse, IamSherwood, KennyP and 1 other said thanks
#354 KennyP OFFLINE
  • 38,299 Thanks
  • 45,895 posts
Posted June 27, 2014 - 07:50 PM
Thanks, Daniel! I bookmarked the page!
#355 olcowhand ONLINE
  • 41,131 Thanks
  • 31,413 posts
Posted June 27, 2014 - 10:08 PM
Here are the carriage bolts for the trim.
http://www.ebay.com/...=STRK:MEBIDX:IT
Here are the nuts for the bolts.
http://www.ebay.com/...=item5d445dcc7d
Edited by olcowhand, June 28, 2014 - 07:30 AM.
  • Texas Deere and Horse and KennyP have said thanks
#356 IamSherwood OFFLINE
  • 8,391 Thanks
Posted June 27, 2014 - 10:09 PM
Thanks Daniel for the pictures and explanation. It all makes sense now.
#357 Texas Deere and Horse ONLINE
  • 14,810 Thanks
  • 15,499 posts
Posted June 27, 2014 - 11:56 PM
Thanks Daniel, Both links are for the bolts.
#358 olcowhand ONLINE
  • 41,131 Thanks
  • 31,413 posts
Posted June 28, 2014 - 07:32 AM
I edited my post.  I went to the page twice & link copied the same.  Guess because I did it from "my ebay" page.  Looked the nut up manually & got the right link.
  BTW....these are the thin style nuts so they don't stick out so far.
  • Texas Deere and Horse and sacsr have said thanks
#359 olcowhand ONLINE
  • 41,131 Thanks
  • 31,413 posts
Posted June 28, 2014 - 09:38 AM
Spent a few minutes down at the shop before heading to town.  These stainless 10-24 carriage bolts work awesome for the trim!  Bolts gripped into the trim snug enough no need to hold anything....the nylock nuts went right on!  One thing to not...check the holes in the hood to make sure all are large enough for the square carriage lock section to pass into the hole freely.  A couple of mine are too tight.  That or grind the square tips of the bolt slightly beforehand.
#360 olcowhand ONLINE
  • 41,131 Thanks
  • 31,413 posts
Posted June 28, 2014 - 09:50 AM
BTW...in the last pic, there is a hole at rear end of the hood side trim.  That is for the hood latch which I should have filled with weld, but I forgot.  This hood is off a D4-10 that used the latch.  This V4-6 can't use a latch on the variator side.   :wallbanging:   Might just leave as-is.
