Bolens Model 12b01 Spark Plug?
4 replies to this topic
#1 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,844 Thanks
  • 2,336 posts
Posted November 01, 2012 - 01:31 PM
Hi guys!
I just picked up a Bolens walk behind with a plow set up. Has the briggs model NPR6 on it, looks to be original, however it doesn't have a spark plug. Would you happen to know the model SP I need? NGK? Thanks!
#2 DougT OFFLINE
DougT
    Dog Approved
  • 7,137 Thanks
  • 5,092 posts
Posted November 01, 2012 - 02:10 PM
The original probably would have been a Champion J8. Not sure if you can still get them or not but most small engine plugs are the equivalent.
#3 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,844 Thanks
  • 2,336 posts
Posted November 01, 2012 - 08:21 PM
Original I am not worried about as I am not restoring it. I just want to get it running again. I've read that the NGK B6S is the same, can anyone confirm? Thanks
#4 DougT OFFLINE
DougT
    Dog Approved
  • 7,137 Thanks
  • 5,092 posts
Posted November 02, 2012 - 06:14 AM
BUT... With the original number and a little cross reference you can find any brand number you want. The modern equivalent to the J8 is the CJ8Y. In the list below, the first 2 numbers are NGK. Like I said, any small engine plug would work. This list was all one line on the chart. At the very end are the dimensions.
1029 BPMR6A-10 N/A N/A CS42S 2974 N/A N/A 7543 WS8F 848 CJ8Y 5613726 N/A N/A N/A N/A A42N 6032 W20MPR-U10 N/A N/A N/A N/A N/A N/A N/A CHAIN SAW STD. GASKET 14MM .375 .750 YES
#5 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,844 Thanks
  • 2,336 posts
Posted November 03, 2012 - 12:29 PM
I understand and thank you for the info. I am an NGK dealer, so figured that would be easier to locate.
Got the spark plug in, and now no spark.
