74 Jd 110
transaxle
3 replies to this topic
#1 Kevin Vasich OFFLINE
Kevin Vasich
  • 87 Thanks
  • 174 posts
Posted October 31, 2012 - 05:04 PM
Hi Has anyone try to fix a transaxle. If you have please give me tip or tricks. My 74 110 need shaft. I got a part transaxle from a 78 214 low hour on the parts transaxle. My dealer say look for c19 on the parts transaxle. What can I find this number the numbers I found are part numbers?
#2 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,551 posts
Posted October 31, 2012 - 09:13 PM
I would suggest swapping full transaxles if you have a known good replacement. Everything on the exterior of the 110 transaxle will bolt to 214 transaxle.
What shaft do you need? I have an extra good input shaft if you need one.
#3 sam s OFFLINE
sam s
  • 3 Thanks
  • 23 posts
Posted November 02, 2012 - 07:45 PM
He need both axles. They are woren pretty bad. Kevin told that the other trans is a NOS but roars in 4th gear. Does anyone think y it roars?
#4 Kevin Vasich OFFLINE
Kevin Vasich
  • 87 Thanks
  • 174 posts
Posted November 05, 2012 - 07:05 PM
Hey Trav1s can't swap transaxle. The low hour one is not good. I got it apart now. I got it as a parts I got with my 78 214. I was told it has less then 200 hour on it. The guy told me it was on the tractor and he was cut grass and then, It locked up. He fix a transaxle, put it in the 214. How do I get the break shift out. I'm put this transaxle in my 74 110.
Also tagged with one or more of these keywords: transaxle
