Mf Elf Resto Started.
548 replies to this topic
#91 Gav694 OFFLINE
Gav694
  • 267 Thanks
  • 184 posts
Posted November 15, 2012 - 04:29 PM
Kinda tight for doing the wiring, if it's mounted on the dash.
If I could only get rid of that dip stick, and shift the battery forward.
Do I really need a dipstick?
Could you use a smaller battery to give you more space?
  • IamSherwood said thank you
#92 olcowhand OFFLINE
  • 44095 Thanks
  • 32301 posts
Posted November 15, 2012 - 04:32 PM
That's the way to go. This Briggs doesn't require a high amp battery, so a garden tractor battery would be plenty, and half the size/weight to boot.
#93 Gav694 OFFLINE
Gav694
  • 267 Thanks
  • 184 posts
Posted November 15, 2012 - 06:14 PM
Hope these are what you need Will
View of engine and battery
The Body of the Exhaust is 3.5" from the chassis, 3" wide and 4.5" long
From the front
12.5" high
From the side
#94 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 15, 2012 - 09:27 PM
Thanks for all the help Gav. That's perfect. Exactly what I was looking for.
I like that front PTO engagement lever/setup on yours. I hadn't seen that before.
The muffler, sure sticks out the side a long way.
#95 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 15, 2012 - 09:29 PM
I'm not sure yet. I'm using Google translator, to read the manual. It screws up sometimes.
It says something about "magical Elf liquid".
Must be for those highspeed runs.
Forgot to add a smiley to this when I posted it.
:smilewink: :smilewink:
#96 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 16, 2012 - 04:39 AM
Yep, that's the answer. I was kinda worried about hanging that large battery on the dash. Plus, it's closer to original.
#97 Gav694 OFFLINE
Gav694
  • 267 Thanks
  • 184 posts
Posted November 16, 2012 - 01:41 PM
Posted Imageolcowhand, on November 15, 2012 - 02:38 AM, said:
I must have missed something....what is the small tank for?
Warm Schnapps, Shaken not stirred to go with the cigars from the cigar box :beer:
  • Texas Deere and Horse, IamSherwood, KennyP and 1 other said thanks
#98 UncleWillie OFFLINE
  • 16500 Thanks
  • 9061 posts
Posted November 16, 2012 - 02:08 PM
Pretty swanky to have a humidor and a flask. Do you have to wear a tux to ride it?
Edited by mybigwarwagon, November 16, 2012 - 02:09 PM.
  • KennyP and Gav694 have said thanks
#99 olcowhand OFFLINE
  • 44095 Thanks
  • 32301 posts
Posted November 16, 2012 - 02:55 PM
Only while watching "Green Acres". :D
  • FirefyterEmt and KennyP have said thanks
#100 Gav694 OFFLINE
Gav694
  • 267 Thanks
  • 184 posts
Posted November 16, 2012 - 04:08 PM
No bother at all Will,
The front PTO I guess was an option to go with the mid mounted mower decks I Have. I think there are a couple of front pto units on German ebay just now, one manual and one electro magnetic but they may not suit your briggs engine
The exhaust is quite large, are you going to try to fit something similar?
#101 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 16, 2012 - 07:51 PM
Anyone familiar with this.
German Glee Wine Glubwein
2 lemons
2 cups water
8 to 10 whole cloves
1 stick cinnamon
3 tbsp. sugar
1 qt. red Bordeaux-type wine
GERMAN GLEE WINE GLUBWEIN: SERVED IN GERMANY AND SCANDINAVIA:
STRAIN LEMON JUICE AND CUT THE THIN RIND INTO FINE SLIVERS. PLACE IN ENAMELED SAUCEPAN WITH WATER, SPICES AND SUGAR. BRING SLOWLY TO A BOIL, ADD WINE AND HEAT THOROUGHLY BUT DO NOT BOIL. SERVE HOT IN HEATED PUNCH CUPS. MAKES ABOUT 12 SERVINGS.
Mom makes it for us at Christmas, and sometimes, when we're working out in the cold. It really warms you up.
So, copper wrapped around that tank, and plumbed into the exhaust, might be a new option for the Elfs.
#102 Gav694 OFFLINE
Gav694
  • 267 Thanks
  • 184 posts
Posted November 17, 2012 - 04:42 AM
Did you save the pic of the green Elf Will?
Edited by Gav694, November 17, 2012 - 03:54 PM.
#103 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 17, 2012 - 07:39 AM
Yesterday, I got all the small parts sandblasted, and primed.
Also made up a new battery tray and mounted it. Now there's room for the regulator where
it's supposed to be. I had to lengthen and curve the oil dipstick tube, and gained about an inch
that way, between the battery and dash, making room for wiring/switches.
  • Gav694 said thank you
#104 KennyP ONLINE
  • 50026 Thanks
  • 52252 posts
Posted November 17, 2012 - 08:24 AM
Good progress, Will! I really like that Gav is posting some pics here too.
#105 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 17, 2012 - 08:30 AM
I'm speachless. :tapping_fingers:
