Mf Elf Resto Started.
548 replies to this topic
#46 olcowhand OFFLINE
  • 44097 Thanks
  • 32301 posts
Posted November 04, 2012 - 08:13 PM
These will be more of a car horn sound, where the ELF likely has a buzzer type, similar to moped horns. But these are cheap & flashy chrome.
http://www.harborfre...-set-99911.html
#47 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted November 04, 2012 - 08:24 PM
Well, isn't oompah-pah a popular sound from it's homeland?
  • IamSherwood said thank you
#48 KennyP ONLINE
  • 50117 Thanks
  • 52295 posts
Posted November 04, 2012 - 08:25 PM
Those are just what the Elf needs to make his presence known, Daniel!
#49 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 04, 2012 - 08:29 PM
Here's one with horn, and a snip from the parts book.
#50 olcowhand OFFLINE
  • 44097 Thanks
  • 32301 posts
Posted November 04, 2012 - 08:31 PM
Yep, a "buzzer" style. If you want to look/sound OE, get one off a moped or small motorcycle and it'll look almost identical to the original. I prefer more of a "muscle" sound myself, as my Massey 1010 has the buzzer type, and it sounds whimpy. But, to stay as close to original as possible, then whimpy horn it is. :smilewink:
  • kwj427 and IamSherwood have said thanks
#51 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 04, 2012 - 08:39 PM
I've got one like this in the cupboard. It's got enough muscle, to let you know when I cross the border. :thumbs:
But I think I'll keep it OE.
Edited by IamSherwood, November 04, 2012 - 08:40 PM.
#52 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 04, 2012 - 09:28 PM
Some where wondering about all the levers.
A-diff lock
B-hand parking break. Also has foot pedal steering brakes.
C-PTO lever. 3 positions, engine speed, neutral, axle speed (used to drive optional 2WD trailer)This lever is duplicated
at the rear of tractor.
D-Transfer box lever. Selects between gears 1&3 or 2&4.
E-Gear selector. Reverse, neutral, low, hi.
  • kwj427 and KennyP have said thanks
#53 UncleWillie OFFLINE
  • 16500 Thanks
  • 9061 posts
Posted November 04, 2012 - 10:12 PM
And now we know. Nice to know they all serve a purpose.
#54 olcowhand OFFLINE
  • 44097 Thanks
  • 32301 posts
Posted November 04, 2012 - 10:17 PM
Will, that trans looks like it came from a combine or something....built very heavy duty!
#55 KennyP ONLINE
  • 50117 Thanks
  • 52295 posts
Posted November 05, 2012 - 05:38 AM
Gonna take a bit to remember which lever to go for. Rather busy area around those levers.
#56 mjodrey OFFLINE
  • 2373 Thanks
  • 13481 posts
Posted November 05, 2012 - 06:07 AM
Looks like a well built machine.
#57 Gav694 OFFLINE
Gav694
  • 267 Thanks
  • 184 posts
Posted November 05, 2012 - 01:25 PM
Hi Will this is what I tried to send via the messenger, If someone can tell me how to attach photos to a PM i would be grateful.
Will is this what you meant by backrest? the radius shown is best guess.
On the rear there is another pressed bit bolted on with the lights and reflectors
This rear piece is pressed with a 7/16" folded edge on the top and sides
  • kwj427, IamSherwood and KennyP have said thanks
#58 Gav694 OFFLINE
Gav694
  • 267 Thanks
  • 184 posts
Posted November 05, 2012 - 01:31 PM
Again what i tried to PM
I Will sort some pics of the air filter and exhaust soon.
All i have done so far is get the cast aluminium grill surround welded
Buy an 8' x 4' sheet of punched hole mesh to replace the shortened grill, i could not find a supplier to sell a smaller size but it is a perfect match to the original
Strip and paint front axle and replace wheel bearings
#59 Gav694 OFFLINE
Gav694
  • 267 Thanks
  • 184 posts
Posted November 05, 2012 - 01:37 PM
I haven't played with them yet, but, with the 3 wires, they must be hi/lo
Correct, Do you still have the original Bosch ignition switch? turn the key left is lo to the right is high and push on the key cranks the dynostartor.
The Horn is also a Bosch unit i can get a close up pic and see if there are any numbers on it
Numbers are
A7108
HO/FCH
AGREE TPAR 379 380
IGM 0877 KA
After taking the photo I hooked it up to the battery to see what it sounds like - Silence it doesn't work
Edited by Gav694, November 05, 2012 - 06:14 PM.
  • kwj427, MH81 and IamSherwood have said thanks
#60 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 11, 2012 - 07:50 AM
Thanks for the pics and info Gav.
Do you have a description of sorts, of that perforated grill? What size holes, and what the pattern is called
by the manufacturer?
I don't have that original switch. I'll have to keep an eye out for one.
  • kwj427 said thank you
