Mf Elf Resto Started.
548 replies to this topic
#496 Fabman OFFLINE
Fabman
  • 257 Thanks
  • 374 posts
Posted January 25, 2013 - 01:15 AM
Fantastic build there Will. Totally awesome. :rocker2:
  • IamSherwood said thank you
#497 KennyP OFFLINE
  • 50024 Thanks
  • 52249 posts
Posted January 25, 2013 - 05:22 AM
All I can say is WOW! That's is cool, Will! Ski's look good on it!
#498 Gav694 OFFLINE
Gav694
  • 267 Thanks
  • 184 posts
Posted January 25, 2013 - 07:01 AM
Will, das ist sehr gut.
#499 olcowhand OFFLINE
  • 44095 Thanks
  • 32301 posts
Posted January 25, 2013 - 09:32 AM
Will, that is very good!
#500 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 26, 2013 - 10:08 AM
Thanks guys for all the compliments. I've had a lot of fun doing
this, and a bunch of help from many of you guys. Thanks.
It's time to start another part of this Elf project.
I'm hoping I can get some ideas from you here.
Being the skis are not OE, and just something to play with in
the winter, I have to do something for the rears, to make it
functional. I haven't tried it yet, but my gut feeling is, it won't
be going to far in the snow, without chains, and/or wider tires
to give it more floatation.
The stumbling block I have is the OE hubs, and the 32mm hex axles.
This pic is OE setup.
The triangular hub slides on to the axle. The red plate is held in place
on the end of the axle, with the large nut. Below the nut, is a bolt, that spins
freely in the red plate, and is threaded into the hub. This allows the wheels
to be adjustable in width. On the back side of the hub is a bolt that when
tightened, locks the hub to the shaft, more positively (no pic). It's not a real good
design, i think. Over time, the internal hex in the cast hubs, wears, and
the fit becomes sloppy. You get a bit of sideways wobble.
All that said, I don't want to use the existing hubs for whatever sort of winter wheel
arrangement I come up with. The cast hubs are only bearing on the axle, about 2"
in length. Putting wider tires, or duals, or ??whatever, would be just too much load
on them, and be looking for trouble.
Any ideas, on what might be available, or how I could build some hubs to fit/adapt
on to the 32mm hex axles? I've done a bit of looking on the net, with no luck.
Once I get something more substaintial on the axles, I can build from there.
Thanks for any input.
#501 olcowhand OFFLINE
  • 44095 Thanks
  • 32301 posts
Posted January 26, 2013 - 10:11 AM
Some farm equipment uses hex shafts.  I may even have something around here to look at.  It would be next to impossible that thwe sizes would match though, but I'll dig around.
#502 Texas Deere and Horse OFFLINE
  • 15109 Thanks
  • 15570 posts
Posted January 26, 2013 - 10:17 AM
I'll do some checking on an idea I have and get back to you Will. There maybe a way to do this.
#503 KennyP OFFLINE
  • 50024 Thanks
  • 52249 posts
Posted January 26, 2013 - 10:23 AM
Since it has the option to adjust width, could you use a set of wider wheels with more inboard offset that bolt to your hubs? That way the width would be more centered to what the axles are set up for now. Just a thought?
#504 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 26, 2013 - 10:34 AM
One option I thought, was to get another set of hubs from across the pond, and
have 2 per side, but that would be too expensive, if I could find any, and they'd
probably be worn out anyways.
I'd rather fab something, or source locally.(North america)
#505 Ryan313 OFFLINE
  • 3440 Thanks
  • 5250 posts
Posted January 26, 2013 - 10:49 AM
This skis are awesome will!
For the hex, you might be able to weld some flat bar into a hex. It would not be ideal, but possible.
#506 Texas Deere and Horse OFFLINE
  • 15109 Thanks
  • 15570 posts
Posted January 26, 2013 - 10:53 AM
Will, I went to a couple steel suppliers I use here and there are round OD. tube made with HEX ID., but it will be Monday before I can see if any of them can get some of it.  If we can find the right size, you can Fab. your own hubs to put on the axles.
  • caseguy, IamSherwood and boyscout862 have said thanks
#507 Cat385B OFFLINE
    Tractorfanatics.com
  • 14747 Thanks
  • 10288 posts
Posted January 26, 2013 - 11:10 AM
Check your local steel supplier, Will. I recently picked up 7/8" hex for a pto shaft. They had 7/8", 1", 1 & 1/4". (31.75 mm) They also had stock piping that the hex would slide into.
  • Texas Deere and Horse, IamSherwood and boyscout862 have said thanks
#508 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 26, 2013 - 11:20 AM
Hey :dancingbanana:
That would be perfect Brian. Anything can be done from that point on.
I just double checked. (actually triple) 32mm is what the axles are. A bit loose
would be Ok, as I could drill and tap several set screws/bolts in.
I can see it now. I'll rob the 26 x12 x12's of my MF14, and find a set of logging chains.
http://www.google.ca...=19&tx=72&ty=79
  • Texas Deere and Horse, KennyP and boyscout862 have said thanks
#509 Texas Deere and Horse OFFLINE
  • 15109 Thanks
  • 15570 posts
Posted January 26, 2013 - 11:24 AM
You would diffidently have plenty of traction with that setup.!! :thumbs:
#510 JDBrian OFFLINE
  • 9666 Thanks
  • 14162 posts
Posted January 26, 2013 - 12:02 PM
I haven't checked in here for a few days. The Ski's look superb Will. Beautiful craftsmanship/fabrication. I think some of the older Kubota compacts had hexagonal axles. I don't know if the size would be right though.
