Mf Elf Resto Started.
548 replies to this topic
#301 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 13, 2012 - 09:51 PM
Update--Air intake.
After searching for quite some time, for an OE Oil bath Air cleaner, and having no
luck, I started looking for a reasonable facimile. I went to both farms up here in
northern Ontario, talked to my pack rat buddy, and again, no luck.
I mentioned it to Alan (MH81), and several days later, I had one in my hands.
Many thanks Alan.
Yesterday, I rounded up some parts I found in the shed, and decided to get it installed.
First, I made up a turtle neck collar, to fit the carb.
Then, got things tacked together, and started on the air cleaner mount.
Then I finished the welds, and cleaned them up.
Then I decided I didn't want to actually use an oil bath, and try to adapt a paper
element filter into the canister. So I gutted the canister, and am now trying to
figure out how that can be done, Any ideas?
Oh, Alan, in case you're wondering why that tractor of yours stopped running, it
might have something to do with this. I found this in the air cleaner.
#302 Cat385B OFFLINE
    Tractorfanatics.com
  • 14747 Thanks
  • 10288 posts
Posted December 13, 2012 - 09:55 PM
It's okay, he doesn't need that one. He's right-handed, the left just stays in his pocket all the time anyway.
#303 olcowhand OFFLINE
  • 44097 Thanks
  • 32301 posts
Posted December 13, 2012 - 09:56 PM
Oil bath filters actually work very well when properly maintained. If it were me, I'd leave it as oil bath, but each to their own. That's the smallest oil bath filter I've seen!
#304 UncleWillie OFFLINE
  • 16500 Thanks
  • 9061 posts
Posted December 13, 2012 - 10:01 PM
you found a nail or the glove?
#305 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 14, 2012 - 12:48 AM
I found the nail in there. Sorry, I put it on the glove so it didn't get lost on the
steel table.
#306 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 14, 2012 - 12:50 AM
I'm sure Alan said it's out of a Massey Harris Pony
#307 mjodrey OFFLINE
  • 2373 Thanks
  • 13481 posts
Posted December 14, 2012 - 07:27 AM
Looking good ,Will. :thumbs:
  • IamSherwood said thank you
#308 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
I think I found a filter that'll work.
http://www.stenspart...roducts_id=1476
I'll take that ring out of the oil pan. The pan is 3" ID at the bottom. The air in tube is 1 3/8", and I have
6 3/4" of space to work in between the bottom of the pan, and the baffle up in the cannister.
The Stens filter is 3 od x 1 1/2 id x 5 7/8 long.
I'll glue a piece of inner tube with a 1 3/8 hole, to the filter to create a good seal on the
air in tube. Just to make sure, it doesn't work it's way up on the air in tube, and restrict the air out
flow, I'll take a piece of 1 1/2 id pipe, cut to correct length, weld a 1 3/4" id washer to it, and
slide it down the air in tube prior to installing the filter. Should do the trick.
#309 KennyP ONLINE
  • 50117 Thanks
  • 52295 posts
Posted December 14, 2012 - 07:33 AM
So the air in will come through the center of the filter? May have to watch for it clogging a bit sooner that way, not as much surface area in there.
#310 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 14, 2012 - 07:46 AM
Yes, correct. Elf isn't going to see too much dusty service, but I'll keep an eye on it.
That'll give me a reason to spend some quality time in the shop. :thumbs:
#311 KennyP ONLINE
  • 50117 Thanks
  • 52295 posts
Posted December 14, 2012 - 07:50 AM
Should work fine then. Quite different approach, but keeps the look correct.
#312 shorty OFFLINE
shorty
  • 6031 Thanks
  • 5505 posts
Posted December 14, 2012 - 07:51 AM
Great work! This is interesting to follow your work.
#313 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted December 14, 2012 - 08:21 AM
Will, glad it's working out as you'd hoped.
The oil bath is off a c. 1950 MH Pony, for those wondering... Couldn't see putting a non-Massey Air cleaner on it :D
As for the engine problems... I guess you "nailed" it.
Looking great Will, like it was supposed to be there.
I hope the filter doesnt fight you.
#314 Gav694 OFFLINE
Gav694
  • 267 Thanks
  • 184 posts
Posted December 16, 2012 - 08:58 AM
Or, if I had more Elfs..........
Patio Elfs........
Todays the day to put your bids in!
http://www.ebay.de/i...7#ht_590wt_1186
30 mins to go
Edited by Gav694, December 16, 2012 - 02:06 PM.
#315 Gav694 OFFLINE
Gav694
  • 267 Thanks
  • 184 posts
Posted December 16, 2012 - 02:38 PM
Come on who's bought it then?
Sold for Euro 2710, that makes me feel an awful lot better about what i've spent on mine
John
