Mf Elf Resto Started.
548 replies to this topic
#151 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 27, 2012 - 06:00 AM
What colour paint you using will, I opted for a tin of Massey industrial yellow from my local Massey dealers John
I finally remembered to write it down, and bring it home.
M1023 Bright Industrial Yellow
Part # 841682M2
  • FirefyterEmt said thank you
#152 KennyP ONLINE
  • 50935 Thanks
  • 52621 posts
Posted November 27, 2012 - 07:45 AM
Yep, it's YELLOW!
  • IamSherwood and Cat385B have said thanks
#153 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 27, 2012 - 10:02 AM
Yep, it's YELLOW!
:rolling: :rolling: :rolling: Yep, Kenny you where right on the money.
#154 mjodrey OFFLINE
  • 2374 Thanks
  • 13481 posts
Posted November 27, 2012 - 10:07 AM
Can't put anything over on Kenny. :D :D :D :D :D
#155 Gav694 OFFLINE
Gav694
  • 267 Thanks
  • 184 posts
Posted November 27, 2012 - 01:19 PM
Yep, it's YELLOW!
Kenny just to make 100% sure is it this colour!! :rolling:
John
#156 KennyP ONLINE
  • 50935 Thanks
  • 52621 posts
Posted November 27, 2012 - 06:02 PM
Looks yeller to me. That's how we say it down here in Okieland!
  • Gav694 said thank you
#157 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 29, 2012 - 06:41 PM
Update.
Re bushed the front axle. Cleaned up, primed and painted all the nuts/bolts.
Did a bunch of painting.
The brake, PTO, gear shift, and diff lock linkage rods, which where originally galvinized, I
degreased, washed with vinegar, wire wheeled, and then sprayed with laquer.
Unbutchered the rear fender pan mounting brackets, and straightened them out.
At some point, the left side, must have taken quite the blow from the top. Both brackets, where
twisted, and leaning to the left.
  • olcowhand said thank you
#158 Cat385B OFFLINE
    Tractorfanatics.com
  • 14749 Thanks
  • 10288 posts
Posted November 29, 2012 - 08:10 PM
Starting to look like something, Will. Thanks for the update and pics.
Yep, it's YELLOW!
KennyP, original staff writer on 'The Mr. Obvious Show'.
  • IamSherwood said thank you
#159 UncleWillie OFFLINE
  • 16501 Thanks
  • 9061 posts
Posted November 29, 2012 - 08:33 PM
Not wasting any time on it are you.
#160 coldone OFFLINE
coldone
  • 1716 Thanks
  • 1709 posts
Posted November 29, 2012 - 08:48 PM
I bet you cant wait to get her out and running around. I am really looking forward to seeing what it can do. looking good!
#161 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted November 29, 2012 - 09:00 PM
Yes, pretty anxious to take it for a spin, but a lot to do yet.
#162 tinner OFFLINE
tinner
  • 504 Thanks
  • 1561 posts
Posted November 29, 2012 - 09:43 PM
Love this project. Can't wait to see her all spiffed up.
#163 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 01, 2012 - 07:28 AM
I decided to weld some gussets on to the fenderpan mounts. I noticed, looking
at a picture of Gav's Elf, that his brackets are bent, just as mine where. I guess,
most people board/dismount their nobble steed on the left side, and eventually,
end up bending it. Gav, you might want to do something similiar.
The joint, where the diagonal meets the upper horizontal bar is a weak spot.
  • sacsr and Gav694 have said thanks
#164 KennyP ONLINE
  • 50935 Thanks
  • 52621 posts
Posted December 01, 2012 - 07:43 AM
Looks like a nice upgrade, Will.
#165 Gav694 OFFLINE
Gav694
  • 267 Thanks
  • 184 posts
Posted December 01, 2012 - 08:01 AM
Thanks Will I will have a look at that when I get going with mine for real.
I noticed on mine with the mid mounted mower fitted it is very awkward to climb on, there is just no where to put your feet. So I can see how the Mudguards get used as a support/handle to aid mounting
The Green Elf has made its way to Newcastle :D so I will collect it on monday, must remember to take the camera with me!
John
  • MH81, caseguy and IamSherwood have said thanks
