Need Front End Help
4 replies to this topic
#1 Horvik OFFLINE
Horvik
  • 16 Thanks
  • 64 posts
Posted October 30, 2012 - 05:46 PM
Hey;
On my Jacobsen tractor (UT 345001) is there a thrust washer between the kingpin and the front axle?
Book does not show one.
Thanks
#2 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted October 30, 2012 - 06:17 PM
Not sure about your model, but there was not one on my Ford 195. I made one out of thin metal to take up the wear of thirty years of use. Tighten the axle up nicely.
#3 KennyP ONLINE
  • 40,181 Thanks
  • 46,792 posts
Posted October 30, 2012 - 06:23 PM
I would say it doesn't have one. Mine doesn't have one.
  • Horvik said thank you
#4 Horvik OFFLINE
Horvik
  • 16 Thanks
  • 64 posts
Posted October 30, 2012 - 07:23 PM
I appreciate all the help fellas.
My weight box works out better than anticipated.
Prior to filling with weight, rear tires would easily slip on wet grass. Now filled with approximately 300 lbs, it climbs a stiff 30 % grade like a mountian goat.
#5 skyrydr2 ONLINE
  • 3,908 Thanks
  • 3,411 posts
Posted October 31, 2012 - 07:33 AM
No no thrust washers. I just did my fathers axle to get rid of the slop .
