Snow Blade Help
17 replies to this topic
#16 jusjeepn OFFLINE
jusjeepn
  • 84 Thanks
  • 120 posts
Posted November 02, 2012 - 08:57 PM
That lift arm fits because that is where the mid mount cultivators fit. How much room do you have between the frt tires and the blade? I'm betting not much. That dozer frame is what we call a short frame. It's made to fit the short frame tractors from 1964 through 1969. Your tractor is a long frame. If you would switch to a long frame blade I think you'd be a lot happier
#17 BairleaFarm OFFLINE
BairleaFarm
  • 1,322 Thanks
  • 1,770 posts
Posted November 03, 2012 - 08:02 AM
I've got enough room to usethe blade at a 45* angle. I'd like to come up with another blade that I can use the adapter on to clear the forward swept axle.
Sent from my HTC One X
#18 jusjeepn OFFLINE
jusjeepn
  • 84 Thanks
  • 120 posts
Posted November 03, 2012 - 08:13 PM
If you look at my post with all the pics, you'll see my version of the extension kit I built in pics 2 and 6. That blade was also extended to be 60". works great!
