Correct bore for Kohler in an Original?
3 replies to this topic
#1 earthgrinder ONLINE
earthgrinder
  • 1,128 Thanks
  • 499 posts
Posted August 12, 2010 - 09:05 PM
Kohler manual says bore for an Original 7hp K161 is 2.938" while the IH manual says the bore is 2.875". Which one is correct?
#2 caseguy OFFLINE
  • 1,629 Thanks
Posted August 14, 2010 - 12:02 AM
I would say, unless there are more numbers to the model number, that I would trust the Kohler manual. If there are additional numbers / letters, there might have been a special build for IH. However, those additional numbers usually indicate added features such as a different oil pan or carburator, not a different displacement. The "extra" stuff is denoted pretty well on the Kohler website. If you have the original manual, you may not have this info, so here's a link just in case. just my $.02.
http://www.kohlereng...pdf/tp_2379.pdf
I have also added the manual to the "manuals" tab on this site. Hope this helps.
#3 olcowhand ONLINE
  • 42,369 Thanks
  • 31,793 posts
Posted August 14, 2010 - 11:40 AM
Seems as I recall this coming up at an engine repair forum, perr.com. If I remember right, there were a few engines that did come 2.875, but rare, and parts not available, requiring boring to the 2.938.
#4 jpcubs OFFLINE
jpcubs
  • 6 Thanks
  • 24 posts
Posted August 28, 2010 - 05:27 AM
You are rite olcowhand I have an early cub cadet 3 diget ser. # It has 6 3/4 hp eng. The rest of my orgs. have 7 hp. both are listed in IHC manual. jpcubs
