Need The Onan Boys Help..
18 replies to this topic
#16 Texas Deere and Horse OFFLINE
  • 14,729 Thanks
  • 15,470 posts
Posted October 29, 2012 - 10:51 PM
Also check that manifold for leaks. I have seen them separate where the two have are sealed and riveted together.
These Onans a notorious for leaking manifolds along the split. That would explain the need for some choke. I've been lucky so far.
I will pull the carb/intake and inspect the 2 piece intake. Sprayed around most of it and didn't hear any change in the engine.
#17 KennyP ONLINE
  • 37,382 Thanks
  • 45,444 posts
Posted October 30, 2012 - 05:54 AM
If you found no change when spraying along that seam, then I would say the intake is not leaking. But a visual check may show something.
#18 Texas Deere and Horse OFFLINE
  • 14,729 Thanks
  • 15,470 posts
Posted October 30, 2012 - 03:21 PM
Didn't spray around the flanges that mate to the block, will have to check there this evening.
#19 olcowhand OFFLINE
  • 40,322 Thanks
  • 31,161 posts
Posted October 30, 2012 - 03:25 PM
Carb spray can cause an rpm increase if there's a leak, where WD40 drops the rpm.
