What Stator Do I Have?
26 replies to this topic
#16 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 06, 2012 - 04:39 PM
I will try that to remove the carbon, thanks!
Definitely not a 1.25 or 3 amp! That is a 15amp stator. Usually they have black leads, but maybe it was a PK thing with the red. You should have had a regulator that those leads connected to???? Or has it ever charged since you had it?
I usually just use a dull putty knife to scrape carbon off, but spraying it with gasket remover first softens it up to come off easy.
Thanks Daniel! The leads went to a rectifier, not a regulator.
EDIT: Yes, it charged when I got it in August of 2011. It charged fine up until about April, then I would have to charge it about every three weeks. It slowly got worse and worse to where I only got a few hours of use before it would not run. And, only about an hour of that time was good strong running.
I used a can of carb cleaner to soften the crud, and a plastic putty knife, and small dremel with wire brush atachment. 2. be carefull drilling out that screw, but 3 should hold the stator fine. 3 that looks like the one I have.... If interested I would be willing to sell mine. truthfully I don't remember what it came off of, so some size measurements (Inside . Outside diameter) to make sure mine would work first. I count the same number of coils on both, so that is a plus.
I appreciate the offer, but this is something I would rather just buy new. I am sure your's works just fine, though.
Edited by Ryan313, November 06, 2012 - 04:41 PM.
#17 olcowhand ONLINE
  • 41,127 Thanks
  • 31,413 posts
Posted November 06, 2012 - 05:25 PM
With just a rectifier, it has to charge full rate all the time. I would consider getting a regulator/rectifier so it won't overcharge the battery on extended run times.
#18 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 06, 2012 - 05:31 PM
Can you explain a little better? Can my rectifier also be a regulator? Or are you saying I need both?
#19 olcowhand ONLINE
  • 41,127 Thanks
  • 31,413 posts
Posted November 06, 2012 - 07:11 PM
You know the youtube that Larry posted shows what appears to just be a 4 pole bridge rectifier. They turn the AC into DC, but I see no regulator in this system. A regulator/rectifier combo only has 3 poles....2 AC poles, and one DC that goes to the battery.
Can you post a close-up pic of your rectifier?
  • larrybl said thank you
#20 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted November 07, 2012 - 11:04 PM
The rectifier needs to have a good ground.The stators and flywheels are specific to each other and can't be interchanged as far as 10 and 15 amp are concerned.
#21 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 08, 2012 - 05:17 PM
Here is a shot of the rectifier. The two terminals without wires are for the stator, the other terminal goes to BOTH the ignition, and the light switch.
#22 olcowhand ONLINE
  • 41,127 Thanks
  • 31,413 posts
Posted November 08, 2012 - 05:42 PM
Ryan, that is a regulator/rectifier. And it is a 15 amp system. If you need a new regulator/rectifier, this is the cheapest place I've found to get them, but do check with our site sponsors first. This one is $39 delivered to your door.
Early Style Regulator
#23 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 09, 2012 - 03:12 PM
Now that we know how many amps the system is, does anybody know a part number?
Thanks Daniel! But, this is another thing I would rather buy new. I don't think I need to replace it anyway.
#24 olcowhand ONLINE
  • 41,127 Thanks
  • 31,413 posts
Posted November 09, 2012 - 03:49 PM
That is a brand new aftermarket regulator/rectifier. No part # on the stator, but I'll look.
#25 olcowhand ONLINE
  • 41,127 Thanks
  • 31,413 posts
Posted November 09, 2012 - 03:53 PM
Here is a new stator on ebay, and it's from the same "Pat's Small Engine" as I linked you to the regulator.
New Stator
#26 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 09, 2012 - 08:03 PM
Thank you Daniel! I will order a stator, and head gasket! Maybe I will finally have my tractor back!
#27 olcowhand ONLINE
  • 41,127 Thanks
  • 31,413 posts
Posted November 09, 2012 - 08:05 PM
I have bought from Pat in the past, and likely will again. Good service.
